Guest Posted June 15, 2007 Report Share Posted June 15, 2007 My Mum and Dad bought me a camcorder the other night for graduating, It has a 27mm lense, which I want to buy either a wide angle lense or a fish eye lense for, but have a few questions that I expect someone here can answer.What's the differance between a fisheye lense and a wide angle? From what I can see they both do the same thing, just in differant ways, fisheye tends to 'distort' the image somewhat while a wide angle lense seems to maintain a normal look.........Where can I get (cheap) lenses?I have found this:http://cgi.ebay.co.uk/27mm-0-45X-Wide-Angl...1QQcmdZViewItembut am more after a fisheye if what I've said above is true.Can anyone offer any advice as to where I could pick up a 27mm fisheye online??? Quote Link to comment Share on other sites More sharing options...
GlynnP Posted June 15, 2007 Report Share Posted June 15, 2007 You have pretty much got it fisheye gives it this distorted 'rounded' effectWhere as wide angle gives you a a normal look but with a wider field of view.As for lenses i dont know of many best place is ebayBut for a normal dv camcorder it seams you can normally just get cheapy onesI had a cheap fisheye for my mini-dv camera spent about £20 on it was fun but quality wasnt great. Quote Link to comment Share on other sites More sharing options...
Greetings Posted June 15, 2007 Report Share Posted June 15, 2007 0.45x is very wide yet doesn't distort the image too much unless your filming indoors.0.6x has very little distortion and is good for pretty much everything but the view angle is much lessi think an 0.6 is a wide angle lens, whereas 0.45x is a semi-fisheyeobviously the better the lens, the less distortion there will be Quote Link to comment Share on other sites More sharing options...
Janson Posted June 15, 2007 Report Share Posted June 15, 2007 pretty much. in my time, i have used one of those raynox snap-on fisheyes and a better raynox fish. both are listed as 0.3x, but the snap-on gave more distortion and more wide angle.better and expensive one, raynox 3031cheap snap-on, raynox qc303I much prefer the 3031. Less fisheye, much better image quality, and zoomable. Camera can't focus when zooming through the qc303.i also own a 0.6x sony wide angle lense. pretty pointless if you ask me, but i guess it can be OK depending on the situation. Nothing great for trials, as you either want very wide or not at all. Quote Link to comment Share on other sites More sharing options...
