Cant Think / Wich Frame
JoeEden
How tall are you? Because you've only got the option of a wheelbase of 1085 with the GU, whereas the Czar obvisouly comes in short aswell which is 1075. Also a differance in both of the frames are the Bottom bracket rise, that will affect riding. The BB rise on the GU is a lot higher (60mm) than the Czar (35mm).
I know this doesnt help but looks wise id go for the GU, but riding wise i would go for the Czar.
Al
GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU
GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU ***, lol
Out of the two I'd choose the Czar. High-bb frames suck, I've been struggling with mine for almost 10 months and I really really hate it.
Still don't understand how you can't decide between the two. They've got totally different geometry, people won't help you choose a frame if you don't tell us about what kind of riding you're into and what you expect from a frame.
GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU ***, hehe.
Well i would go for the GU just because it looks nicer and has good Geo, but it depends on the components that you have if it will look nice on the frame.
but GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU guru GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU GU u GU GU GU GU GU GU GU GU GU GU
