Stvn V. Posted June 13, 2007 Report Share Posted June 13, 2007 hmm,i'll maybe buy a new frame,but don't know what to get..control or zhi ?i've heard the zhi has a lot of flex ?cheers Quote Link to comment Share on other sites More sharing options...
ConnorPowell Posted June 13, 2007 Report Share Posted June 13, 2007 Zhi you dont see as many about as you do controls! And they look nicer Quote Link to comment Share on other sites More sharing options...
Conor the basher. Posted June 13, 2007 Report Share Posted June 13, 2007 Zhi you dont see as many about as you do controls! And they look nicer There is a reson why you don't see as many out there lol echo is the best choice by miles. Quote Link to comment Share on other sites More sharing options...
c3jae Posted June 13, 2007 Report Share Posted June 13, 2007 heres the geo for both frames, thanks to trialsman and tartybikesZHI• Wheel base: 1080mm • Rear Chainstay: 380mm • Head angle: 72 degrees • Bottom bracket rise: +35mm • 1 1/8” head tube • Dedicated 4 bolt mounts • CNC machined dropouts/Chainstay yoke • Weight: 2000gControlWheelbase: Short 1060mm, Long 1080mmChainstay Length: 375mmBB Rise: 20mmHead Angle: 72 degreesCentre of BB shell to top centre of head tube: Short 655mm (25.75"), Long 675mm (26.5")it may seem small but the extra rise on the zhi bottom bracket will effect the ride of that bike SO much, ive ridden both frames and ive owned more than 1 echo control, so im going from personal experiance, there both amazing bikes to ride, it just depends weather you want the high bb or not, if your new to trials id probly recomend the ZHI as it will help improve balance slightly quicker and will feel alot easier to ride because of the slight rise on the bb Quote Link to comment Share on other sites More sharing options...
