_Owen. Posted June 11, 2007 Report Share Posted June 11, 2007 (edited) As my monty should be arriving tommorrow i am considering going rear disk, but not sure what to go for? as it is going to be rear i want to be able to have alot of trust in it whilst gapping etc so will not want a crappy slippy one. also i dont want to spend too much money on it, so no carbon £200 stuff! i also think i may be able to get a hope mono mini for pretty cheap, so is that a good option to go for? i would appreciate reccomendations cheers, owen Edited June 11, 2007 by owentrialsman Quote Link to comment Share on other sites More sharing options...
Mod Man Leo Posted June 11, 2007 Report Share Posted June 11, 2007 Mono trial,BB7's belong on the front, Quote Link to comment Share on other sites More sharing options...
Grant H Posted June 11, 2007 Report Share Posted June 11, 2007 Mono trial,BB7's belong on the front,mono trials suck even on the front185mm bb7 would do fine Quote Link to comment Share on other sites More sharing options...
Greetings Posted June 11, 2007 Report Share Posted June 11, 2007 a 180mm Mono Trial will be perfect, no need for more powerbb7 would be good on a stock wheel Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted June 11, 2007 Report Share Posted June 11, 2007 mono trials suck even on the front185mm bb7 would do finealthough before you committ I STRONGLY suggest you find someone with a monty frame + a bb7 on the rear to make sure it does fit. I can tell you now a bb7 does not fit smoothly/without modification on a hydroxx frame because there is a large weld in the way where the mounting braket goes. Quote Link to comment Share on other sites More sharing options...
Grant H Posted June 11, 2007 Report Share Posted June 11, 2007 although before you committ I STRONGLY suggest you find someone with a monty frame + a bb7 on the rear to make sure it does fit. I can tell you now a bb7 does not fit smoothly/without modification on a hydroxx frame because there is a large weld in the way where the mounting braket goes.bahh never thought about it fitting, just the power it would have Quote Link to comment Share on other sites More sharing options...
_Owen. Posted June 11, 2007 Author Report Share Posted June 11, 2007 although before you committ I STRONGLY suggest you find someone with a monty frame + a bb7 on the rear to make sure it does fit. I can tell you now a bb7 does not fit smoothly/without modification on a hydroxx frame because there is a large weld in the way where the mounting braket goes.i never thought of that,i will have to check that one out, cheers mate and cheers to everyone else for the fast replys, keep them comming Quote Link to comment Share on other sites More sharing options...
Louis p Posted June 11, 2007 Report Share Posted June 11, 2007 i would suggest either the Avid bb7 or the new 07 hope mono trials. Both these brakes are amazing and you hold on anything. I have used both brakes on the front but only the hope brake on the back and the hope brake was imense. I would recommend the hope disk over the bb7 but its your choice. The bb7 would be the cheaper option as the hope is £150!cheers lou. Quote Link to comment Share on other sites More sharing options...
Muel Posted June 12, 2007 Report Share Posted June 12, 2007 mono trial *** Quote Link to comment Share on other sites More sharing options...
20inch_power Posted June 12, 2007 Report Share Posted June 12, 2007 (edited) Hi mate, i would go for the 2007 Hope mono mini trials, not the mono mini, cause i had one of thoes and there just is not enough power behind them, as they are made for XC riding.iv heard that BB7's explode if they are put on the rear god knows??Hope ***!!...cheers...Shaun.. Edited June 12, 2007 by 20inch_power Quote Link to comment Share on other sites More sharing options...
*BOOTHY* Posted June 12, 2007 Report Share Posted June 12, 2007 Hi mate, i would go for the 2007 Hope mono mini trials, not the mono mini, cause i had one of thoes and there just is not enough power behind them, as they are made for XC riding.iv heard that BB7's explode if they are put on the rear god knows??Hope ***!! Quote Link to comment Share on other sites More sharing options...
ARV* Posted June 12, 2007 Report Share Posted June 12, 2007 Hope mini for sure Quote Link to comment Share on other sites More sharing options...
c3jae Posted June 13, 2007 Report Share Posted June 13, 2007 180 hope, with out a doubt, avids heat up and tend to fail on you when there needed the most. Quote Link to comment Share on other sites More sharing options...
