Maggie Playing Up. Grrrr
rudirudirudirudirudi
ok, to put this simply, my maggie is bien sh*t. It bites like a baby and holds terribly. i have green rock pads quite worn down but still about 4/5 mm left. i dont see any reason why that should affect the performance. i gave the magura a fresh bleed, and my echo 06 rim(i think) a fresh fairly deep grind. i also cleaned the pads and it still performs like sh*t. I have got some ali c joypads but i need some tensile mounts to fit them as my frame is real narrow. the pads used too be great but i think theyve just got worse since iv got the new wheel.( 06 echo). what should i do???
I dont think that green rock pads go well with a deep grind mate they say there made for a smooth rim.
That could be why or maybe you have some air trapped in the magura so maybe try bleed it again.
Cheers.
well they worked great before with the same grind. and the bleed was fine, cylinders went to the rim with the tpa all out.
