Mod Stems
ogre
i'm buying a new stem soon, i've currently got a V!Z highrise stem and i wanted to try something lower+longer i like the look of the V!Z logic and echo team stem. whats the advantages of lower+longer stems then?
ZOO! frame if that makes a difference
Edited by ogre
what i find on mod bikes is the higher the bb rise the more likely u need a higher rise stem. when i hat my zoo i used a zoo stem which is kinda like the monty stems. it felt pretty decent with that set up and riser bars. just find what best suits you :)
it's not the shortness, it's the angle i'm bothered about (Y) does it make keeping the front end up easier or anything?
I find lower stems easier on the back wheel.
On tarty, they have adapted the images to overlay each other, so you can see the diference of each stem. The Try-All and Echo Team are the same height, but the Team is a bit longer, I have a long wheelbase so went for the Try-All with some 07 Adamant bars, these have to be the best upgrade I have done for the geometry of my bike. It is much nicer on the back wheel and I can turn whilst hopping on the spot now, and back-wheeling things is so much easier now.
