ruption0 Posted June 10, 2007 Report Share Posted June 10, 2007 Peoples views on the t master rear hub please as i have orderd this hub recently and wondering if anyone has had problems or compliments to the hub.Thanks in advance Scott. Quote Link to comment Share on other sites More sharing options...
ManxTrialSpaz Posted June 10, 2007 Report Share Posted June 10, 2007 Smooth enough and seems sturdy so far. (Not much use though) The bolts are shit though. I'd recommend making sure that if you have chain tugs, that they're not bent. Quote Link to comment Share on other sites More sharing options...
ruption0 Posted June 10, 2007 Author Report Share Posted June 10, 2007 ok seems like not to bad then by one person anyone else have an opinon? Quote Link to comment Share on other sites More sharing options...
Tylerlovesalex Posted June 10, 2007 Report Share Posted June 10, 2007 Yea they come with alloy Axel's think they snap quite easy but just wack a steel one in and your laffing!yea there amazing apart from that! Quote Link to comment Share on other sites More sharing options...
Muel Posted June 11, 2007 Report Share Posted June 11, 2007 Yea they come with alloy Axel's think they snap quite easy but just wack a steel one in and your laffing!yea there amazing apart from that!I'm thinking of getting one, is it possible to stick a T-Pro axle in, run on bolt up? I guess it could be adapted, they tend to be fairly simple things internally. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted June 11, 2007 Report Share Posted June 11, 2007 T-Pro hubs have standard unsealed axles. Whereas T-master hubs have the axles machined for the sealed bearing cartridges.So no, you won't be able to convert it.They're good hubs. I borrowed my mates for a while last year and it was fine. 'Fit and forget' kinda thing. Quote Link to comment Share on other sites More sharing options...
Muel Posted June 11, 2007 Report Share Posted June 11, 2007 T-Pro hubs have standard unsealed axles. Whereas T-master hubs have the axles machined for the sealed bearing cartridges.So no, you won't be able to convert it.They're good hubs. I borrowed my mates for a while last year and it was fine. 'Fit and forget' kinda thing. My Dad works on a lathe, do you reckon he could copy it, but make it in stainless steel? He could probably make it M8 bolts as well... Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted June 11, 2007 Report Share Posted June 11, 2007 My Dad works on a lathe, do you reckon he could copy it, but make it in stainless steel? He could probably make it M8 bolts as well...Probably.As long as he gets the right diameter sothe bearings can still press on, then it'd be fine.You want to keep the bearings the same size as standard, if you make the axle bigger, the bearings will have to be smaller. = weaker.You might've already worked that out, but still... But yeah, should be fine. Quote Link to comment Share on other sites More sharing options...
Muel Posted June 11, 2007 Report Share Posted June 11, 2007 Probably.As long as he gets the right diameter sothe bearings can still press on, then it'd be fine.You want to keep the bearings the same size as standard, if you make the axle bigger, the bearings will have to be smaller. = weaker.You might've already worked that out, but still... But yeah, should be fine. Sweet, if I ever get one and manage to break the axle, then he can make me one.Here is a public note, If you ever want anything that is perfectly round making, I can get it done, you need to send me the broken bits and a cheque, then we will copy it in stainless. Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted June 11, 2007 Report Share Posted June 11, 2007 Sweet, if I ever get one and manage to break the axle, then he can make me one.Here is a public note, If you ever want anything that is perfectly round making, I can get it done, you need to send me the broken bits and a cheque, then we will copy it in stainless.So can Dave 85 on here! lol! I think he'll do anything! Quote Link to comment Share on other sites More sharing options...
