Aluminum Welding
Matthew_Gibson
I have a BRAND NEW pair of Echoi lite forks being welded, as I f**king cut it about 40mm too short :sick: Made me cry inside. I just wondered if they would need heat treated after welding the back. The guy at the fabrication shop said hes going to do them. I'm just a bit gutted that I payed £70 and fort I'd f**ked them.
If I cnt get em sorted right, whats the shorted they can be on a deng frame or any other with 100mm head tube. There 140mm, too short for anything?
Avoid welding at all costs. Well, too late now.
Simpler solution - go to a turner, have him make an extension that you hammer and glue into the steerer to extend it. Probably would have cost 2x less, would also retain the strength of the metal. I'd definitely not trust a welded steerer. It's probably the most stressed part of a bike?
I put some insulatio0n tape round the fords a to cut them in a hurry cut the at the bottom one, and they were supose to cut at the top one! I was raging with myself. but as I have a good engneering place round the corner. (british steel wold have been best, ano there NOT steel) I went there explained to the guy, who was sceptical about it, but she says he CAN do it! I'll be going down there tmora to see his work. opefully theyll be good!
If they do snap at the weld. I can make one up at school/get one done by the metal work guy and see how that goes. But its like what Ali C done with his bars. You did it too!
I'm sure a lad on here got the welded Rob i think his name was, on a white BT Maybe that was Trials Nation. (back in the day:))
Thanks!
Yeah, i wouldn't really trust a weld on its own without having some kind of extension in place. Just welding it back together wont be as strong as having a specially lathed metal insert that goes down an inch or two into the steerer tube and sits flush with it above where you cut it.
Unless he puts a smaller metal ring inside the steerer than welds into place using that i wouldn't even think about attaching a stem to it.
He's going to shamfer the edges. If the worse come to it, ill make a piece, but that will just "slipped" in there, With plenty of lube and a hammer. well see how it goes. VERY worse case, new(er) forks! bit gutted and they are nice forks. I suppose £70 isnt bad i guess, but I have limited cash for a while. as im buying a car soon.
i REALLY wouldnt weld them, they WILL break.
bad luck mate !
ask of he can put a little tube inside as well and weld it all together,
but they will still break, will last longer though.
sry mate
iolo.
I have an idea for you.
Its not the best drawing ever, but i think you can tell whats going on.
If you can't well you get a lathe and turn off a peice of metal the same size as your steerer. Then bit down the post you cut a little bit extra off. 2 mm bigger than the center of your steerer. Then you make a thread on the inside of your steerer and on the outside of your new peice of turned off metal.
Then drill a hole in your peice of metal the same size as the hole was on the inside of your steerer so that your starnut will go in.(Don't go all the way through your peice of metal of you will spoil your thread)
Then you cover both threads in loctite and screw togather as tight as possible. Wait for the loctite to set in.
Then ride.
Not sure if it will work but worth a try I'd say would say it will be stronger then welding it.
Matt Rushton
Then ride.
Matt Rushton
I mite do what the pic says. But without the thread and jst hit it in!
Or i mite TRY and sell em (ha ha ha lol) and get a new set and make sure I check before cutting em!
But then there is the chance of it pulling out with a thread there isnt.
Matt Rushton
:unsure::(
How long do you think they'll last? weeks? days?
if you just weld them together then think more like minutes. you have to remember it wont fit through your headset as the weld will bulge out abit.
either sell them to someone and get new ones or you could try the turning another piece method. it ll break though
WAIT ! i have it !!
ages ago in an evans catologe there was....
a steer tube extender !!!!
was a piece of ALU the same diameter as the steer tube, but has a small end which pushed into your fork, then an allen key
which expanded the small end in your fork, and locked it in there. (then you stem when on it.,or half on it)
search, or ring Evans
iolo.
this might sound a bit silly but what you could do is
use the thread idea, then once you have threaded it in insert a long tube the same length as your steer all the way through your fork and weld it at the top and bottom and then use a thread lock.
its just an idea, as you will have a weld thread and a solid tube the same length as the steer, would make it heavier but would be alot stronger than just having a weld, you could also weld where it was threaded together so would be ultra strong
