trials_pimp Posted June 7, 2007 Report Share Posted June 7, 2007 Is there an actuall difference in Front and rear BB7 calipers?Most times fromt and rear difference would be the lever and the length oh cable/hose.Looking for a BB7 ive noticed they sell them front/rear specific.Is there a difference in the calipers, mounts or rotors that make this?I dont care about levers, as I have one I want to use Quote Link to comment Share on other sites More sharing options...
Tomm Posted June 7, 2007 Report Share Posted June 7, 2007 It's just the mounts, the front ones have a bigger mount (+20mm) so to run a front 185 on the back you'd need a disc that was 205mm. I think I've got that the right way around. Either way, you can buy the mount adapters separately.EDIT: Yeah I've got that the wrong way round I think. Quote Link to comment Share on other sites More sharing options...
trials_pimp Posted June 7, 2007 Author Report Share Posted June 7, 2007 so the caliper its-self is the same, just a 205 rear would mount up to be a 185 front.Awsome. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted June 7, 2007 Report Share Posted June 7, 2007 (edited) Yes, a 180mm FRONT bracket is a 160mm REARA FRONT BB7 bracket is +20mm when used as a REARJust for improved clarity to answer you're question mr teeth, no a 203mm rear is a 223 front Edited June 8, 2007 by PaRtZ Quote Link to comment Share on other sites More sharing options...
Mod Man Leo Posted June 7, 2007 Report Share Posted June 7, 2007 Ive got a 185 REAR adaptor for sale, Worth a try Quote Link to comment Share on other sites More sharing options...
Prawny Baby Posted June 7, 2007 Report Share Posted June 7, 2007 It's just the mounts, the front ones have a bigger mount (+20mm) so to run a front 185 on the back you'd need a disc that was 205mm.Yes, a 180mm FRONT bracket is a 160mm REARA FRONT BB7 bracket is +20mm when used as a REARto answer you're question mr teeth, yes a 203mm rear is a 185 front s'wrong guys......its the OTHEDR way round.partz, your first bit is right, a 180 front setup will run on a 160mm rear disc.a 203mm rear brake setup would need a 223mm front rotor to run up front.take any brake, of and given size. for rear fitting, that calliper will always need a 20mm smaller disc, than if used up front.this is of course for IS standard mounts.the rear disc mounts are closer to the axle than the fronts. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted June 8, 2007 Report Share Posted June 8, 2007 s'wrong guys......its the OTHEDR way round.partz, your first bit is right, a 180 front setup will run on a 160mm rear disc.a 203mm rear brake setup would need a 223mm front rotor to run up front.take any brake, of and given size. for rear fitting, that calliper will always need a 20mm smaller disc, than if used up front.this is of course for IS standard mounts.the rear disc mounts are closer to the axle than the fronts.arghh sorry you're right ive just read it! thanks prawn!!! Quote Link to comment Share on other sites More sharing options...
