B.E.A.U Posted June 5, 2007 Report Share Posted June 5, 2007 i had my king for ages and it wobbles now and has for a while and i cant stop it its the hd one and o took it all apart and put it together tightend lock ring and it still wobbles bad. only thing i can think of is the bolt on the lock ring coler is rounded and so i cut into it wit ha saw to make a scrw driver but i cant get it tight nough i think im not sure could this be why. i cant think of nothing else really need help please guys. hate kicking on biek and it hits pad thanks beau Quote Link to comment Share on other sites More sharing options...
max-t Posted June 5, 2007 Report Share Posted June 5, 2007 Do the axle collar up as tight as you can with you hand, then tighten the bolt up. Quote Link to comment Share on other sites More sharing options...
Shaun H Posted June 5, 2007 Report Share Posted June 5, 2007 Or get a new HD collar. Quote Link to comment Share on other sites More sharing options...
dave85 Posted June 5, 2007 Report Share Posted June 5, 2007 Talk to me beau, might be able to save your skint arse a few quid... Quote Link to comment Share on other sites More sharing options...
T-Limburn Posted June 6, 2007 Report Share Posted June 6, 2007 theres no reason really why your screwdrvier 'bodge' wouldnt do the collar up i dont think.i dont do mine up that tight, even with allen keys, purely because its such a shit bolt that it will round!maybe just undo the screw, then tighten the actual collar and then retighten the screw.although im guessing youve tried that mate... Quote Link to comment Share on other sites More sharing options...
Anodised Adamant Posted June 6, 2007 Report Share Posted June 6, 2007 Do the axle collar up as tight as you can with you hand, then tighten the bolt up.THIS WILL CURE YOUR PROBLEM HOPEFULLY Quote Link to comment Share on other sites More sharing options...
Trials Punk Posted June 6, 2007 Report Share Posted June 6, 2007 Whens the last time it had a proper service?Are the bearings regreased and splines regreased then lubed back up?Check the bearings for play.Check this video out, this should help you.LQGUIDE1.WMV Quote Link to comment Share on other sites More sharing options...
