Little Problems With Bike
If its all new and you havn't put enough grease on the joining parts, it may just be rubbing when a lot of force is put on it.
Thae it all out and regrease the bb cup threas, axles and crankbolts... as well as the pedal threads.
My bike was doing this last weekend, all it needed was tightening up the bottom bracket
What bottom bracket have you got on now then?
If you're riding this weekend remind me to take a look at it if it isn't sorted by then!
Alex
Hi,
Just bought new cranks bottom bracket and freewheel, but scence these have been put on my koxx seems to click whenever i cycle faster that normal riding.
Can you Sugest anything to do
Chears Matt
I also had this problem, it turned out to be serious. The bearings had fallen out of place and were clicking everytime i pedalled faster. At first I did not notice, and i phoned the shop I bought it from as I had only had it a couple of days. Turns out it was worse than i thought, and eventually the bearings got caught and the cranks didn't turn at all. If you spotted it early then tighten the cranks and BB. This should put them back in place. It doesn't hurt to try.
Hope this helps!
Ben :turned:
May be the crank arm’s are hitting slightly hitting in one place on the chain stay.
No checked all visable stuff cant see anything, strange thing is though the clicking does not seem to affect when going slow(Or in a section).
ihave the same problem , probably because its a sh*t bb, does i t eally matter matt? o and hows the arm.
Arm it Fine go pic on mobile ill send it to you, if you want or ill show you when see you at weekend, You gonna ride a Samerai Manor show?
Lil Chris is gonna come(hopefully if he doesnt bail) and would be good if Dan could Get ben to ride as well.
Hope this helps!
Ben :turned:
Chears will try
Matt
Alex
Hey Alex I wont be in town This weekend as we will be setting up a display of trials at samerai Manor Speak to dan and maybe he can get permision for you to ride, if i don see you this weekend could you bring it the one after
Matt
Edited by jsy trials matt
happens very often when people think their getting a good deal on cheaper freewheels
often people buy freewheels for the front when their designed to go on the back so they
start to go very quickly.
But saying that , it could be a number of things
check chain is right way on
check its not your pedals that are going
check all rubbing of cranks ect...
scott (Y)
