Braided Crossover
Oskar
Hey, im tired of kicking and snapping my plastic magura crossover so I want to get I braided one instead. Tarty and CRC only have a complete set so I will build my own.
This hose: http://www.chainreactioncycles.com/Models.aspx?modelID=2938
But witch fittings is best? Magura or Hope?
Magura: http://www.chainreactioncycles.com/Models.aspx?ModelID=1526
Hope: http://www.chainreactioncycles.com/Models.aspx?modelID=3258
What do you guys recommend?
Thanks
tartys will make you up one using hope parts if you ask. You have to run a water bleed with this. I'm running unex as i can use oil (better for your brake seals etc) and it's been great. And i got 2 for £10 from supercycles!
Hope. Seen the magura ones (on a unex hose actually) dig into the hose itself and split it! Defeats the point really.
Edit: Do you know if you'd need the 5mm or 6mm fittings? Might do the same...
Edited by Quackers
why cant i run royal blood with the crossover braided??
I think it is 6mm for the crossover, M6 and 6mm is the same thing right? I didnt really understand that talk about unex, is it a brand of hose or something? Becouse I will run the Goodridge hose.
yep unex is a brand but they do all the fittings etc and supercycles make them up for you. Tarty's have told me th hope fittings and hose are narrower than the normal magura/unex hosing. I would just have unex if i were you, much easier than doing it all yourself.
