mods Posted June 1, 2007 Report Share Posted June 1, 2007 i have a viz hub which uses fun bolts. My back wheel isn't even nearly staying in place, i go on to the back wheel and it just slides down, i'm not using any tensioners. I'm going to try snail cams, but which ones are better the echo ones with the notches or the viz ones with out, i'm pretty gutted as i just finnished my new bike today and can't ride it! Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted June 1, 2007 Report Share Posted June 1, 2007 i have a viz hub which uses fun bolts. My back wheel isn't even nearly staying in place, i go on to the back wheel and it just slides down, i'm not using any tensioners.ok. You seem surprised... I'm going to try snail cams, but which ones are better the echo ones with the notches or the viz ones with out,In all honesty I've used both and cant notice the difference. I was wary or smooth ones because I thought they'd slip but somehow they aren't The notched ones sit well but obviously you don't get the fine adjustment as smooth one Quote Link to comment Share on other sites More sharing options...
