t33zr Posted May 31, 2007 Report Share Posted May 31, 2007 I got my braided hose kit today. Fibrax!I mounted the hose from the caliper to the lever on my HS33 first... then i bleeded the brake.Then the problems start... when i pull the lever, brake pads go inn to the rim but i loose more and more brake power.When i release the lever an pulls it again the power is still gone.When i wait 10seconds the power is back.Ive bleeded the brake 6 times and there is NO air in the hosing.It don't leak at all either... i used compressor to check the hosing in a bath.Why is this happening? Quote Link to comment Share on other sites More sharing options...
Deonn h Posted May 31, 2007 Report Share Posted May 31, 2007 (edited) If there is no air in it then it must be just shit hosing. Just use braided crossover Isit bled with oil or water? Edited May 31, 2007 by Deonn h Quote Link to comment Share on other sites More sharing options...
t33zr Posted May 31, 2007 Author Report Share Posted May 31, 2007 Its bleeded with water and antifreeze.. it looks like the whole hosing is flexing.... Its frustrating, because i bought the hosing from UK.... Quote Link to comment Share on other sites More sharing options...
