Swapping Them Over
Hi guys I have been thinking fore a bit now. My right hand is my strong hand but I run my leavers like any other person but would I benefit from swapping my hoses over because I have hs33. So would it still work as well by me swapping the hoses over so the front brake is the rear and so the rear is the front let me know what you think to this idea. :unsure:
you would do it, then notice how hard it is for you to ride the bike like that...
Just get used to the left hand back brake, you will learn to get it stronger eventually...
It should work? But i think your ok how it is. Eventually your left hand will get stronger.
i would leave them how they are because if you do switch them over then you are more likely to forget which break is which and pull the front when trying to slow down on a steep drop and after a month or two your hand should get stronger anyway
trials mad andy
Dont you think he would actually learn to ride with opposite brakes before he tried "steep" drops.
Hey when I moved over here from canada, I had to change to Left hand rear brake, Right hand Front Brake, because all the bike came like that, and I found it well hard getting used to it, but I couldnt do it, so its pros best that you stay they wasy you are, also if you do change, you riding will not improve for a while because you will be to focused on trying to use the brakes the oppisite they you normaly do!
Johny
Johny
[/quote
I don’t think I will change any way
