PaRtZ Posted May 30, 2007 Report Share Posted May 30, 2007 I want to run my front disc cable through my top cap + forks. I currently have a monty stem which is angled. Now as far as Im aware the only few people to do hollow star nuts, bolts + top cap sets have them in FLAT varietyFor exampleso im just asking, I need to run the hollow starnut, which takes the hollow m7 (ish) bolt, which needs a big hole in the top cap. Drilling is my last option, but any other ideas?cheers Quote Link to comment Share on other sites More sharing options...
Simpson Posted May 30, 2007 Report Share Posted May 30, 2007 Using a metal bar of the same diameter and make it like a triangle slope, so that the top can sit flat and the sloped bit of metal will take the slope off the topcap? surley wouldnt be that hard if you used a protractor or something and doesnt need to be that strong really..... Quote Link to comment Share on other sites More sharing options...
Krisboats Posted May 30, 2007 Report Share Posted May 30, 2007 I want to run my front disc cable through my top cap + forks. I currently have a monty stem which is angled. Now as far as Im aware the only few people to do hollow star nuts, bolts + top cap sets have them in FLAT varietyFor exampleso im just asking, I need to run the hollow starnut, which takes the hollow m7 (ish) bolt, which needs a big hole in the top cap. Drilling is my last option, but any other ideas?cheers Why is drilling the last option? Monty are one of the very few companies who do sloped stems, so your almost going to have to buy one of these and drill the hole bigger in the monty top cap. Its not really too big of an issue is it? Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted May 30, 2007 Report Share Posted May 30, 2007 Just curious, why do you want to put it through there?Would it not be easyer to get a longer hose? because the rear would just get tangled too, if your planning on twisting the bars loads.Matx Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted May 31, 2007 Author Report Share Posted May 31, 2007 Just curious, why do you want to put it through there?Would it not be easyer to get a longer hose? because the rear would just get tangled too, if your planning on twisting the bars loads.MatxI run dual avid bb7 so i can get a gyro ahaok im gna get drilling when i can ge arsed. thanks all Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted May 31, 2007 Report Share Posted May 31, 2007 don't get a giro, they make the break really hard to pull and are generally more problems than they are worth. Quote Link to comment Share on other sites More sharing options...
ogre Posted May 31, 2007 Report Share Posted May 31, 2007 I run dual avid bb7 so i can get a gyro ahaok im gna get drilling when i can ge arsed. thanks allother than to be cool(er) why? is it for barspins + such (mm wide bars ***...) or to save the cables when you cock up? Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted May 31, 2007 Author Report Share Posted May 31, 2007 mainly for flatland tailwhips. Ive been learning them for a year on a bmx and couldn't get them so i want them nailed now. I just want a different setup that doesn't restrict my moves Quote Link to comment Share on other sites More sharing options...
ogre Posted May 31, 2007 Report Share Posted May 31, 2007 aha, cool good luck with it man fancy trying sidehop to frontwheel static-tailwhip jobbies would look nutz hehe Quote Link to comment Share on other sites More sharing options...
Brian Bleech Posted May 31, 2007 Report Share Posted May 31, 2007 mainly for flatland tailwhips. Ive been learning them for a year on a bmx and couldn't get them so i want them nailed now. I just want a different setup that doesn't restrict my moveswill a giro even work? they pull the correct amount of cable for U/canti brakes, but vee brake levers pull more!odyessy linear slic is the way forward just run it a bit longer for the rear, works just the same when it is wrapped around the frame after a whip... Quote Link to comment Share on other sites More sharing options...
RobinJI Posted May 31, 2007 Report Share Posted May 31, 2007 A well set-up gyro will work with a Vee break fine, they can pull just about enough cable. Also a well set-up good quality gyro will still give a very well performing break, but you might have a job finding a rear cable section long enough for use with a rear disc.To be fair a long slick cable should still give an easy 2 or 3 rotations, which is by far enough for most people. But it still helps to put the front break through the top-cap. Front break cables get tangled way easier than rear ones. (oh yeah, I'm pretty sure there M8 if it helps at all) Quote Link to comment Share on other sites More sharing options...
