Gear Ratio Help?
This may have already have been posted before but i couldnt find the answer so.......
Would changing the gear ratio on my bike make any differences on how high and far i can crank hop etc..? Or is it just the way the body movment is on the bike? Or both? Thanks Nigel
Edited by shogun_gimp
Would changing the gear ratio on my bike make any differnts on how high and far i can crank hop etc..? Or is it just the way the my body moment is on the bike? Or both? Thanks Nigel
its probably abit of both really, i expect (looking at your bike) a higher gear would help, maybe 22/18 or 16/14, and learning technique by watching more experienced riders, just my opinion though,
Ben G WST
gaaah!!
almost all mod riders run 18-12 (ratio is 1.5:1) because it gives a good balance of power and liftyness
22-16 is ok (ratio is 1.375:1 ), it's slightly easier to get the front up but you lose a bit of power on gappy moves.
there's no point comparing to stock gear ratios because the wheel size makes it completely different
if you run anything too different from 1.5:1 on a mod you're just odd and you're probably making life harder for yourself
well don't most mods use 18 12??
no, 16-12.
ups, my tensile has 18, right its 18- 12 soz about that, well from how you ride in your vid
its looks like you could do with a higher gear ratio becouse you put in a lot of effot and
your not pedle kicking (lurching) that far. if it was a tad higher you would find it alot easer
to do biger stuff more smooth. but you also need to put in efort yourself. (Y) cheers soz for upsy.
Edited by Maximus
