Boswell Posted May 28, 2007 Report Share Posted May 28, 2007 Are there any liquid substances thinner than water which you can bleed you break with? Quote Link to comment Share on other sites More sharing options...
Grant H Posted May 28, 2007 Report Share Posted May 28, 2007 apparently WD-40 Quote Link to comment Share on other sites More sharing options...
LiamWood! Posted May 28, 2007 Report Share Posted May 28, 2007 i bled mine with WD 40, it felt mint at the lever after i had finished!dent ride my bike for a couple of days due to the weather, went to go out on my bike pulled the brake it was like squeezing sponge bob square pants!other people say its good but it dent work for me, i just use water and they are fine.Liam Quote Link to comment Share on other sites More sharing options...
Heatsink Posted May 28, 2007 Report Share Posted May 28, 2007 Hi,There's loads of info here:http://www.observedtrials.net/vb/showthrea...1450#post391450Steve Quote Link to comment Share on other sites More sharing options...
Grant H Posted May 28, 2007 Report Share Posted May 28, 2007 just thinking, would the oil used in remote control car shocks work ??as i have some pretty thin stuff.. Quote Link to comment Share on other sites More sharing options...
Boswell Posted May 28, 2007 Author Report Share Posted May 28, 2007 Hi,There's loads of info here:http://www.observedtrials.net/vb/showthrea...1450#post391450Steve Thank you Quote Link to comment Share on other sites More sharing options...
streetzguy Posted May 29, 2007 Report Share Posted May 29, 2007 dot 4 oil is ment to be good. Quote Link to comment Share on other sites More sharing options...
Boswell Posted May 29, 2007 Author Report Share Posted May 29, 2007 dot 4 oil is ment to be good.Yes, but is it thinner than water? Quote Link to comment Share on other sites More sharing options...
Trik Posted May 29, 2007 Report Share Posted May 29, 2007 Use WD 40 its mint Quote Link to comment Share on other sites More sharing options...
Concussion Posted May 29, 2007 Report Share Posted May 29, 2007 (edited) Hi,There's loads of info here:http://www.observedtrials.net/vb/showthrea...1450#post391450SteveThats it, I'm using baby oil from now on, as I fear my crappy tap water may bugger things up over time... as soon as krisboats finds me a syringe!Cheers Steve Edited May 29, 2007 by Concussion Quote Link to comment Share on other sites More sharing options...
gianttrials Posted May 29, 2007 Report Share Posted May 29, 2007 nothing wrong with magura blood if its bled properly, or are youi stupidly trying to save precious grams of weight, hahahahahahaha lmaoB Quote Link to comment Share on other sites More sharing options...
