Cnc Koxx Bloxx
James Quigley
I used that set up and work great prob. the best yet, then i got coust and worked great for the first few days and have fadded in power after a while but my rim is neeeding a good grind been 6-8 months so will try that and see <_<
definately gunna be my next set up.
had coust sinks which were the best.
then had to go koxx brown cos coust refills werent available to order.
now have coust sinks again lol
but wanna try koxx browns in cnc fo sho. ultimate pads!
that looks like an ace set up.i tried koxx browns a long time ago but wasnt impressed at the power.after seeing that set up i wouldnt mind trying that again.how long would a gring last with that set up?
craig
well koxx browns work on adead grind so should last ages
KOXX BLOXX IN HEATSINK BACKINGS IS MOST PROBOBLY THE BEST BRAKE PADS EVER!!!
i have koxx yellows in cncd backing and they better than any other pads i have used they work
no matter what they have the most LLOOUUDDEESSTT BITE! >_< and instant hold you can ride
under water and the brake is still beastly as fuk even on a dead grind with the rim covered in
mud and they last years KOXX BLOXX IN CNCD BACKINGS *** (Y)
