Help Needed
David Biddle™
mines still bled with oil but my friend did it and had to bleed a few times to clear out the oil once this was done it was fine if need be just rebleed with oil again but no reason it shouldnt work
Jack (Y)
Yeah, mine was a bit of a b*****d to do.
I'd recommend using GT85 or similar, if not for the lubricating properties, but it also has a nicer feel to water.
I'd suggest bleeding it as you would normally, then close the caliper end up, and leave it to hang with the syringe/lever end at the top. Keep tapping it, and pumping the lever slowly, and all the air will rise up and out the system. (Y)
