Will Fairburn Posted May 24, 2007 Report Share Posted May 24, 2007 (edited) Hi,Just starting using a digital camcorder and it records media to mini Dv Tapes, but on theside it takes memory cards, if i pt my memory card in and i take my tape out it flashes no tapedoes anyone use a Sony ''DCR-TRV11E'' , If so how can I get it set-up to use my memory card?or How do i put my clips on the computer if i use a tape?Cheers, Will Edited May 24, 2007 by POPPY Quote Link to comment Share on other sites More sharing options...
GlynnP Posted May 24, 2007 Report Share Posted May 24, 2007 For a start this topic is in the wrong area.I dont know about your model of camcorder but lots that have both memory and tapes the memory cards are just for the still images the camera can take.As for putting the clips onto your computer just simply connect the camera via firewire or usb which ever the camera/computer has and use an editing suite to import them. Quote Link to comment Share on other sites More sharing options...
Will Fairburn Posted May 24, 2007 Author Report Share Posted May 24, 2007 Ah, i wasn't sure if it was for just pictures. what camcorders use memory cards, as camera doesnt have a port to link up to a usb only wires to connect to a T.V Cheers, Will Quote Link to comment Share on other sites More sharing options...
GlynnP Posted May 24, 2007 Report Share Posted May 24, 2007 (edited) Keep hunting around the camera because i am sure it will have a conection to the computer might be hidden.EDIT: Is this what you have - LINKIf so this has a Firewire / I.Link to connetc to your computer only problem is your computer might not have a firewire connection. Edited May 24, 2007 by RealRiding Quote Link to comment Share on other sites More sharing options...
Will Fairburn Posted May 24, 2007 Author Report Share Posted May 24, 2007 Keep hunting around the camera because i am sure it will have a conection to the computer might be hidden.EDIT: Is this what you have - LINKIf so this has a Firewire / I.Link to connetc to your computer only problem is your computer might not have a firewire connection.Yep Sure is ,I'll have a search around on websites for a cable to connect and get firewire or something,Cheers mate Quote Link to comment Share on other sites More sharing options...
charlie >est< Posted May 26, 2007 Report Share Posted May 26, 2007 (edited) Hi,Just starting using a digital camcorder and it records media to mini Dv Tapes, but on theside it takes memory cards, if i pt my memory card in and i take my tape out it flashes no tapedoes anyone use a Sony ''DCR-TRV11E'' , If so how can I get it set-up to use my memory card?or How do i put my clips on the computer if i use a tape?Cheers, Will You need to connect your camera to your computer via firewire.I have a iMac with Firewire but I dont think PC's have firewire.If you have a mac open up iMovie and switch to camera mode and click inport.If you dont have a firewire try www.argos.com or www.ebay.co.uk <CheaperSorry I dont use windows for these types of things. Edited May 26, 2007 by charlie >est< Quote Link to comment Share on other sites More sharing options...
Phatmike Posted May 26, 2007 Report Share Posted May 26, 2007 ^ Lol.If your pc doesn't have a firewire port, buy a firewire card. http://www.maplin.co.uk/Module.aspx?ModuleNo=44929 Quote Link to comment Share on other sites More sharing options...
fyfey Posted May 26, 2007 Report Share Posted May 26, 2007 Here's a cheap Firewire card I found on Ebuyer... looks as though It'll do the job.Safecom PCI Firewire 1394A Card with 3 External and 1 Internal Port OEM £6.98 Quote Link to comment Share on other sites More sharing options...
Will Fairburn Posted May 27, 2007 Author Report Share Posted May 27, 2007 Thanks for help lads,i bought a firewire cable and a firewire card off ebay for a fiver Cheers, Will Quote Link to comment Share on other sites More sharing options...
