V Brake Cable
Right, just been out and done some trials, and then I came inside with the bike and noticed that the wire on my back V-Brake has snapped but left 2 wire lines in the holder. There is not alot of room to pull the wire though..... So what should I do, and how much would a new wire cost? Thanks Nigel
Get a hs33 :P
stick with the vees, they have more pros than maggies. Its woth getting some decent cable though, linear slicks at £6 new are some of the best! WD40 is also a good lube, you dont want anything too thick in them, will make the cable sticky and will attract dust and dirt.
Ok. So how do I make then better than maggies?
You just need to play around and find a better set up that works for you. A desent V can cost as much or more than a maggie.
Ben
Err you didn't really answer his question did you.
Although, I will..
This setup will be pretty decent for not too much money:
Avid sd7
Plazmatic CRV's or Heatsink vee brake backings with your chosen pad material.
A grind :turned:
A brake booster
that should provide you with good brakes :)
If you have the money (70 quid, I think) and can warrant spending it then get same as above but avid ultimate brakes..
