Boswell Posted May 18, 2007 Report Share Posted May 18, 2007 A while back i purchased some hope braided hosing for my magura hs33 and i have found i have had a mushy pull ever since. What causes this and have any of you lot have the same problem? Quote Link to comment Share on other sites More sharing options...
James Quigley Posted May 18, 2007 Report Share Posted May 18, 2007 Might not be bleed properly i.e. Air in the brake.Try rebleeding it and see how it goes.Are you using water or oil in your brake? Quote Link to comment Share on other sites More sharing options...
harmertrials Posted May 18, 2007 Report Share Posted May 18, 2007 Follow the tips in the magura problem thread mate. I have goodridge braided hoses and they're wicked, it needs a re-bleed by the sounds of it. Quote Link to comment Share on other sites More sharing options...
Boswell Posted May 18, 2007 Author Report Share Posted May 18, 2007 No it's bled well with water. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted May 18, 2007 Report Share Posted May 18, 2007 trust, its defo the bleed, your your brake pad backings flexing ALOT Quote Link to comment Share on other sites More sharing options...
Boswell Posted May 18, 2007 Author Report Share Posted May 18, 2007 (edited) I have had crap bleeds before and this feels different , it would be interesting to hear from somone who actually used hope braided hosing. Edited May 18, 2007 by mr ? Quote Link to comment Share on other sites More sharing options...
NileBrownâ„¢ Posted May 23, 2007 Report Share Posted May 23, 2007 I have had crap bleeds before and this feels different , it would be interesting to hear from somone who actually used hope braided hosing.boswell , its the bleed mate, I told you that on saturday! Quote Link to comment Share on other sites More sharing options...
Ewannnn Posted May 23, 2007 Report Share Posted May 23, 2007 Maybe the braided hosing is alot longer than your plastic hosing was? Quote Link to comment Share on other sites More sharing options...
Up'n'away Posted May 23, 2007 Report Share Posted May 23, 2007 listen to what most of the people said, its blatently a airy bleed? Why not try rebleed and find out?! Quote Link to comment Share on other sites More sharing options...
N.Wood Posted May 23, 2007 Report Share Posted May 23, 2007 Try a re-bleed.Also, are all the fittings correctly seated? Quote Link to comment Share on other sites More sharing options...
dano Posted May 23, 2007 Report Share Posted May 23, 2007 i used to use goodridgre and it did work realy well but you dont get the response that you get with normal hose! do you have the bridge in braided? Quote Link to comment Share on other sites More sharing options...
Boswell Posted May 23, 2007 Author Report Share Posted May 23, 2007 *UPDATE*I have given it a rebleed and it hasn't worked, i am now considering downgrading back to plastic hosing and selling the braided. Quote Link to comment Share on other sites More sharing options...
