Cnc Backings
Yes RimJam V3's have CNC backings. :)
RimJam V3's
Great post, you really answered his question :S, i mean, its not like the cnc backings are actually made by heatsink and the rimjam ones are cast like magura cylinders.
The cnc backings are available in with both pad material and without it, though having the heatsink material in them for only an extra £4 is a bit of a no brainer decision wise.
Pads can be taken out of plastic backings too, by heating up the glue to break its bond between the backing and the pad. Sticking them in the oven seems to be the most effective way of doing this, though be careful not to burn them :lol:
As above
Pre-heat your oven to 200 degrees.
Place pads on a baking tray and leave in over for just 5mins.
Remove pads from oven (handle with care) and the material should pop out quite easily.
The ninsert material snuggly into Heatsink cnc backings. (dap of superglue if you like)
