El Cristoff Posted May 16, 2007 Report Share Posted May 16, 2007 hi, as title, i have a really lazy magura piston and i want to know how to fix it. Cheers in advanceChris Quote Link to comment Share on other sites More sharing options...
ding_dong Posted May 16, 2007 Report Share Posted May 16, 2007 http://www.trials-forum.co.uk/wiki Quote Link to comment Share on other sites More sharing options...
powerz Posted May 16, 2007 Report Share Posted May 16, 2007 http://www.trials-forum.co.uk/forum/index....showtopic=88410 Quote Link to comment Share on other sites More sharing options...
Rusevelt Posted May 16, 2007 Report Share Posted May 16, 2007 Quick method is to hold or wedge a piece of card between the active brake pad (the pad that IS moving) and the rim/sidewall, and keep pressing and depressing the brake lever. this will bedding the lazy pad by forcing the oil from the active brake pad to the lazy brake pad. do this for a few minutes before removing the piece of card that was wedged between the active brake pad and rim/sidewall, then try again. both pads should pull evenly. Quote Link to comment Share on other sites More sharing options...
Simpson Posted May 16, 2007 Report Share Posted May 16, 2007 both pads should pull evenly.Or blow up in your face follow dan6061's? guide Quote Link to comment Share on other sites More sharing options...
JT! Posted May 16, 2007 Report Share Posted May 16, 2007 Set it up with little or no tpa. Quote Link to comment Share on other sites More sharing options...
Muel Posted May 16, 2007 Report Share Posted May 16, 2007 Set it up with little or no tpa.Always best for me, then if you really need to use it, like when your on a ride, the lazy pad will (hopefully) still not drag on the rim. Quote Link to comment Share on other sites More sharing options...
Ducko Posted May 16, 2007 Report Share Posted May 16, 2007 just get a new piston if you can there crap once they start to stick. Quote Link to comment Share on other sites More sharing options...
