Avid Juicy 7
strat-trials
I have an avid juicy 7 rear disc brake. Is there any way in which i can use it on the front. I know the leaver is able to swap between either sides but just need to know if I can change the removable part of the bracket so that it will work on the front, or if there is an other bracket i can buy to adapt it.
Cheers
Tom
If I happened to have a 203mm disc that i wanted to use would i be able to just buy the bigger adapter to go with?Even though its only originally a 160mm caliper.
Yep, the adapters the only thing that decides the disc size (as long as its standard IS forks/frame) So if you buy a front 203mm adapter, then it'll all go straight together no problem (Y)
(edit: typo)
Edited by Dont you Just Hate it When...
