Mod Man Leo Posted May 14, 2007 Report Share Posted May 14, 2007 Is there a adaptor to get a hs33 onto a bmx brake bosses, its not the same as the v-brake bosses so i dont realy know.Any links/advice much apreciated.TahLeo Ill get some pics ina mo. Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted May 14, 2007 Report Share Posted May 14, 2007 dont botherjust get a decent u brakeor do what i did and weld v brake lugs on and run a v Quote Link to comment Share on other sites More sharing options...
mr_malcolm Posted May 14, 2007 Report Share Posted May 14, 2007 leeson are desinging a bmx frame that runs a hs33 on the rearnot sure when its coming out thoughand also from looking around the net the other day i found a site selling a hydrolic gyrocost about £99 for that alone thoughbut still just imagine not having to worry about your bmx brake slipping Quote Link to comment Share on other sites More sharing options...
liam_thornton Posted May 14, 2007 Report Share Posted May 14, 2007 You just put the bolt that screws into the mount at the top, so the mounts are upside down, my mate has done it. Quote Link to comment Share on other sites More sharing options...
poopipe Posted May 14, 2007 Report Share Posted May 14, 2007 but still just imagine not having to worry about your bmx brake slipping first up - imagine how many times you'll rip the hose out of the caliper in the first week alonesecond - dont run brakes - i think that leeson was a one off Quote Link to comment Share on other sites More sharing options...
Mod Man Leo Posted May 15, 2007 Author Report Share Posted May 15, 2007 You just put the bolt that screws into the mount at the top, so the mounts are upside down, my mate has done it.Got a pic mate?Leo Quote Link to comment Share on other sites More sharing options...
Luano Posted May 15, 2007 Report Share Posted May 15, 2007 Id buy a revenge brake if i was you, absolute mintness, i run one on my bmx , smooth as you like with more bite than a great white. Quote Link to comment Share on other sites More sharing options...
abtrials Posted May 15, 2007 Report Share Posted May 15, 2007 You just put the bolt that screws into the mount at the top, so the mounts are upside down, my mate has done it.seen this done as well works a treatbasicaly you set the brake up the same as you would on v bosses but run the evo mouns upside down so the cylinders are underneath the bosses rather than above.hope it helps Quote Link to comment Share on other sites More sharing options...
liam_thornton Posted May 15, 2007 Report Share Posted May 15, 2007 Got a pic mate?LeoNo, sorry mate.It does work a treat though as rwiley said. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted May 15, 2007 Report Share Posted May 15, 2007 Yeah fitting the calipers works as has been detailed above, the lever can be tricky as you sometimes need to bend it/shorten it 'cos of BMX bars.We managed to nigrig one on, never had any problems with it (till it was stolen). Quote Link to comment Share on other sites More sharing options...
