maty-trials Posted May 11, 2007 Report Share Posted May 11, 2007 hi right iv tried bleeding my brake at least 4 time tonight and it seems to be not doing anything can someone help me Quote Link to comment Share on other sites More sharing options...
gianttrials Posted May 11, 2007 Report Share Posted May 11, 2007 hi right iv tried bleeding my brake at least 4 time tonight and it seems to be not doing anything can someone help mewhat brake is it? Quote Link to comment Share on other sites More sharing options...
maty-trials Posted May 11, 2007 Author Report Share Posted May 11, 2007 hs33 Quote Link to comment Share on other sites More sharing options...
gianttrials Posted May 11, 2007 Report Share Posted May 11, 2007 okay are you bleeding from bottom to top? Quote Link to comment Share on other sites More sharing options...
maty-trials Posted May 11, 2007 Author Report Share Posted May 11, 2007 from the top to the bottom Quote Link to comment Share on other sites More sharing options...
gianttrials Posted May 11, 2007 Report Share Posted May 11, 2007 i could be wrong but i think you have to bleed from bottom to top on hs33s. Quote Link to comment Share on other sites More sharing options...
maty-trials Posted May 11, 2007 Author Report Share Posted May 11, 2007 (edited) well i got sum intuctions of there website and it said from top to bottom Edited May 11, 2007 by maty-trials Quote Link to comment Share on other sites More sharing options...
fbmbmx Posted May 11, 2007 Report Share Posted May 11, 2007 When i bleed my back hs33 i do it in the bath,I do this by filling the bath about half way up with cold water then Put the hold break under water and undo both the bolts (the 5mm one on the calliper and the smaller bolt on the lever).After you have took these bolts out pump the break about 10 times getting all the out water or whatever you used befor out.Then put your finger over the small hole were you removed the bolt from the lever and pull the lever in,take your finger away from the hole and relise the lever slowly and steadly.Do this about 15-20 times and your break should be fine.Hope this helped and good luck Quote Link to comment Share on other sites More sharing options...
gianttrials Posted May 11, 2007 Report Share Posted May 11, 2007 well i got sum intuctions of there website and it said from top to bottom dunno then, only trying to help, maybe you should go to a bike shop or summit Quote Link to comment Share on other sites More sharing options...
maty-trials Posted May 11, 2007 Author Report Share Posted May 11, 2007 ok thanks alot Quote Link to comment Share on other sites More sharing options...
missionmod Posted May 11, 2007 Report Share Posted May 11, 2007 (edited) When i bleed my back hs33 i do it in the bath,I do this by filling the bath about half way up with cold water then Put the hold break under water and undo both the bolts (the 5mm one on the calliper and the smaller bolt on the lever).After you have took these bolts out pump the break about 10 times getting all the out water or whatever you used befor out.Then put your finger over the small hole were you removed the bolt from the lever and pull the lever in,take your finger away from the hole and relise the lever slowly and steadly.Do this about 15-20 times and your break should be fine.Hope this helped and good luck Harry i do your brakes not you lol Anyway what are you using to bleed you brake ?? If your useing water. This is the way iv all ways done it. Works fine. liam Edited May 11, 2007 by missionmod Quote Link to comment Share on other sites More sharing options...
liam_thornton Posted May 11, 2007 Report Share Posted May 11, 2007 When i bleed my back hs33 i do it in the bath,I do this by filling the bath about half way up with cold water then Put the hold break under water and undo both the bolts (the 5mm one on the calliper and the smaller bolt on the lever).After you have took these bolts out pump the break about 10 times getting all the out water or whatever you used befor out.Then put your finger over the small hole were you removed the bolt from the lever and pull the lever in,take your finger away from the hole and relise the lever slowly and steadly.Do this about 15-20 times and your break should be fine.Hope this helped and good luckI tried this but the piston's don't go all the way out and the lever feels really spongy. What shall i do now? Quote Link to comment Share on other sites More sharing options...
missionmod Posted May 11, 2007 Report Share Posted May 11, 2007 I tried this but the piston's don't go all the way out and the lever feels really spongy. What shall i do now?Have you put the tpa in all the way ?? and what he doesnt say is you need to put the bolts back in the calliper and leaver when the brake is still under water as air all get in the brake. Thats what usealy make the brake spungey.liam Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted May 11, 2007 Report Share Posted May 11, 2007 ok this is how i do mine..............like said before but mine goes in the sink......save water heheheh.......take the bolt out from caliper .take grub screw out lever while underwater......get a seringe and some pipe add the fitting to the pipe put in grub screw hole.........bleed your brake under water... pull water in 2 the seringe underwater all the time so no air gets in ........once done put screws back in whilst under waterjob done Quote Link to comment Share on other sites More sharing options...
liam_thornton Posted May 11, 2007 Report Share Posted May 11, 2007 Have you put the tpa in all the way ?? and what he doesnt say is you need to put the bolts back in the calliper and leaver when the brake is still under water as air all get in the brake. Thats what usealy make the brake spungey.liamYeah, that's what i did.Will try that Mrkoxx. Quote Link to comment Share on other sites More sharing options...
