little bmxer boy Posted May 11, 2007 Report Share Posted May 11, 2007 (edited) Monty Brake Spray dose it work as well as tar and dose it last as long. Edited May 11, 2007 by alexonza Quote Link to comment Share on other sites More sharing options...
omgnoseat Posted May 11, 2007 Report Share Posted May 11, 2007 watch your spelling next time, gets you validated sooner I havent used monty spray myself, but I heard that it sticks TOO much, and sticks your pads to the rimTar works perfectly fine, just go with that Quote Link to comment Share on other sites More sharing options...
little bmxer boy Posted May 11, 2007 Author Report Share Posted May 11, 2007 watch your spelling next time, gets you validated sooner I havent used monty spray myself, but I heard that it sticks TOO much, and sticks your pads to the rimTar works perfectly fine, just go with that sorry must have missed that spelling sorry about that. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted May 11, 2007 Report Share Posted May 11, 2007 (edited) I think its some kind of weird glue substance. It is so tacky, too tacky with kool-stops. I think its better just to go with tar...Alex Edited May 11, 2007 by dark_biker Quote Link to comment Share on other sites More sharing options...
bowman12 Posted May 11, 2007 Report Share Posted May 11, 2007 It is beasty stuff. I use it on my T-Mag with ZOO! pads. amazing bite and sound Quote Link to comment Share on other sites More sharing options...
moza Posted May 11, 2007 Report Share Posted May 11, 2007 its quite good but its not realy any better than tar to say it costs like a 5er, if you do get some only put a little bit on as it makes your pads stick Quote Link to comment Share on other sites More sharing options...
fbmbmx Posted May 11, 2007 Report Share Posted May 11, 2007 I found it was to sticky it felt like i had to kick throught my break after i relised it.I use hair spray now and it works fine and sound's nice. Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted May 11, 2007 Report Share Posted May 11, 2007 Also bear in mind the fact how it takes a few minutes to set.My mate had some of it, its a good idea I think but it doesn't look too good when you miss the rim and spray a bit on the tyre. Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted May 16, 2007 Report Share Posted May 16, 2007 Well put a straw off an old WD40 can in the nozzle then... Quote Link to comment Share on other sites More sharing options...
Simpson Posted May 16, 2007 Report Share Posted May 16, 2007 If you ask my opinion putting anything on your rim is rubbish, just grind it and set it up with decent pads! ive mucked about with everything on rims i even used cough mixture... but no sack that nothing like a clean setup Quote Link to comment Share on other sites More sharing options...
grantallsop Posted May 16, 2007 Report Share Posted May 16, 2007 I had monty brake spray. Its pretty good stuff but it sticks the pads to the rim. Amazing when it worn in though. Quote Link to comment Share on other sites More sharing options...
AdamAllen Posted May 16, 2007 Report Share Posted May 16, 2007 Never used it but fan belt adhesive has the same principle and that worked awesome on my old bike but now i have a new set up which i find is the BEST brake i have ever had... water bled 04 magura Zoo! pads on a filed rim! Its a beast of a brake. CheersAdam Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted May 16, 2007 Report Share Posted May 16, 2007 ive used monty spray its ok.......ive used a tiny weenie bit of tar on a clean rim it works slightly better but the best set up by far has to be.......light sharp grind 05 maggie with water bleed and either plazz crm pads ....or koxx reds amazing brake............i would say if you dont wish to run a grind get your self a set of either pads listed above and only a small amount of tar.......works verry welldave Quote Link to comment Share on other sites More sharing options...
Apocalypse_reaper666 Posted May 16, 2007 Report Share Posted May 16, 2007 Before i grinded my rims, i used monty spray and ended up virtually gluing the pads to the rim It does'nt seem to last though. They shouls mould them into pads! Quote Link to comment Share on other sites More sharing options...
Greetings Posted May 16, 2007 Report Share Posted May 16, 2007 If you ride lots in the wet, Monty spray will be much better. It's resin in the form of a spray and that won't wash off easily. On the other hand, tar and water is probably the worst thing you can have on a rim other than grease.That the brake spray has a better function - use it on rails to get really good grip Quote Link to comment Share on other sites More sharing options...
Apocalypse_reaper666 Posted May 16, 2007 Report Share Posted May 16, 2007 Ah! Good idea! Quote Link to comment Share on other sites More sharing options...
simtradan Posted May 17, 2007 Report Share Posted May 17, 2007 i take it that the spray colour is clear, if so it would look a lot better on the rims than using tar, might give it a go one of these days Quote Link to comment Share on other sites More sharing options...
Onza-rider Posted May 17, 2007 Report Share Posted May 17, 2007 it is pritty shit. it just sticks your pads to your rim.just use tar Quote Link to comment Share on other sites More sharing options...
mini_raga Posted May 17, 2007 Report Share Posted May 17, 2007 Hi there, fairly new to this... Its most probaly a stupid question, but is tar something you get in a can? Or is it actually tar, if you get me?Thanks in advance.Chris Quote Link to comment Share on other sites More sharing options...
RossMcd Posted May 17, 2007 Report Share Posted May 17, 2007 heymonty spray doesnt last as long as tar but works the dream. i use a grind though so i dont use tar much anyway Quote Link to comment Share on other sites More sharing options...
Ryan Blackwell Posted May 17, 2007 Report Share Posted May 17, 2007 I put a post up like this the about 2 months ago mate i borght some put it on let it set and found out its absolute crap pads just stuck on the rim and would not let go really annoyed me its just sitting in my room now not being used. Quote Link to comment Share on other sites More sharing options...
T_PRO Posted May 18, 2007 Report Share Posted May 18, 2007 I have tried it once and did not like it that much, I think that grinding your rims is a much better idea. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 18, 2007 Report Share Posted May 18, 2007 This thread is shit.To those people who say it stick's your pads to the rim's and you prefer to use tar, does tar never stick your pads to your rim? If not, it's because you are applying just enough to hold, but not enough to stick. Why can't you apply the same principle to the monty spray?It only sticks the pads to the rim when you use too much. When you know what your doing you can achieve the same effect as tar on your rim, the advantage over tar then being what inur pointed out, wet weather peformance. Quote Link to comment Share on other sites More sharing options...
