Richard jersey Posted May 10, 2007 Report Share Posted May 10, 2007 I want to know whether or not to grind my back rim. At the moment I have a smooth rim with Onza Citrus pads and I just use tar to improve the brake. But some people say that grinding the rim is better and works better in the wet. I'm not sure what to do? Is it worth grinding it? Any help????Richard Quote Link to comment Share on other sites More sharing options...
rudirudirudirudirudi Posted May 10, 2007 Report Share Posted May 10, 2007 i also used too run on a smooth back rim. the brake was good but i found it started to slip when gapping onto it. i bought a angle grinder for £15 and now my brake doesnt slip once. i use tar with it occasionally as well when i need extra bite. grind your rim. its the way forward Quote Link to comment Share on other sites More sharing options...
tom jersey Posted May 10, 2007 Report Share Posted May 10, 2007 Just leave it richard. Alex has just swapped rims because of his grind, leave it like it is. Quote Link to comment Share on other sites More sharing options...
rudirudirudirudirudi Posted May 10, 2007 Report Share Posted May 10, 2007 no dont leave it grind it. lol Quote Link to comment Share on other sites More sharing options...
Anodised Adamant Posted May 11, 2007 Report Share Posted May 11, 2007 Grind it. its a lot better than smooth Quote Link to comment Share on other sites More sharing options...
Up'n'away Posted May 11, 2007 Report Share Posted May 11, 2007 Obviusly grinding is 10x better but has disadvantage such as wearing down your pads and weakening your rim, but personaly i would go for it! Quote Link to comment Share on other sites More sharing options...
joe b Posted May 11, 2007 Report Share Posted May 11, 2007 Ground rim and smooth rims both can be as good as each other, with certain pads. Though, grinding rims will wear yours pads down more and weaken your rim a tiny bit, the increased all-round performed out-weigh's this dis-advantage .Good luck... Cheers,Joe. Quote Link to comment Share on other sites More sharing options...
andits Posted May 11, 2007 Report Share Posted May 11, 2007 (edited) I would definately say grinding is better it just seems to give that extra bite and works much better than smooth in the wet. If you add tar aswell it will just increase the performance, but as everyone else has said it does wear your pads down quicker. In the end its up to you but personally grind is much better!!! Edited May 11, 2007 by andits Quote Link to comment Share on other sites More sharing options...
Richard jersey Posted May 11, 2007 Author Report Share Posted May 11, 2007 Thanks for all the help. I'm quite sure now that I will grind my rim from the advice everyone has given me. But most people have said that a grinded rim only really works with the right pads and some will wear down too quickly. What sort of pads are best from a grinded rim??Cheers, Richard Quote Link to comment Share on other sites More sharing options...
Ben Cox Posted May 11, 2007 Report Share Posted May 11, 2007 (edited) for a grind you cannot beat koxx bloxx browns! really grippy and last a freaking lifetime!bit of a silly question lol, bit like asking whats better, a smooth rim with a caliper brake off of an argos bmx or a hs33 with braided hosing, echo booster, koxx bloxx and a harsh grind Edited May 11, 2007 by Ben Cox Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted May 11, 2007 Report Share Posted May 11, 2007 depends on if you have a rim brake really Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted May 11, 2007 Report Share Posted May 11, 2007 All depends on your set-up.I've always ran standard Magura pads on a smooth rim with some tar (No money to change pads, and my dad is not convinced with the idea of grinding a rim).More recently I've changed my rear pads to Onza Citrus pads (Cheers Al), and it is better than the Magura pads in the sense that the brake can be feathered more before it locks the rim. With my magura pads this was not the case.A good grind and decent pads will you allow you to feather the brake, and have fairly good hold too. Also rembering the fact how a grind will shed away water from the rim, allowing your brakes to work in the wet (Dependant on grind and pads).At the end of the day its up to you, I chose not to get a grind as I was scared that I'd make a bodge or that my magura pads weren't the right combination on a grind. So I just bought some tar and then I can always get a grind when I have the money. Quote Link to comment Share on other sites More sharing options...
BenLeacock™ Posted May 11, 2007 Report Share Posted May 11, 2007 for a grind you cannot beat koxx bloxx browns! really grippy and last a freaking lifetime!bit of a silly question lol, bit like asking whats better, a smooth rim with a caliper brake off of an argos bmx or a hs33 with braided hosing, echo booster, koxx bloxx and a harsh grind Nope i disagree Rock pads *** !! A grind is a better option but it does weaken you rim ! Its up to you really,want to have bout 4 weeks of good riding then buy a new rim. (tryall's will last bout 2 week)or keen putting tar on and have a rim until you want to change! Personaly i would rather have a month of good riding Ben(Y) Quote Link to comment Share on other sites More sharing options...
br3n Posted May 11, 2007 Report Share Posted May 11, 2007 (edited) Dont grind it with citris pads, you'll only get 1 ride out of them... Mate round here has them on a non ground rim, we were all really impressed, 3 bikes and 3 sets of pads later (on grinds) theyre all dead after 1 ride edit: the guy above... what the f**k are you on? 2 weeks for a rim?!?! Loose some weight... Ive never had a rim last less than 8 months for me.. with about 4 grinds as well... Koxx/onza/megamo/alexdx32 (most sold/stolen not replaced) Edited May 11, 2007 by trialsmad Quote Link to comment Share on other sites More sharing options...
Egg Fried Rice Posted May 12, 2007 Report Share Posted May 12, 2007 I use a smooth rim with heatsink reds and i do say, it is frigging amazing, obviously with a bit of tar. But when water gets onto it, im pretty stuffed. If you get a grind, your pads wont last and long and neither will the rim but a grind is more safer and wont slip as a smooth rim would, well less chance anyway.JK Quote Link to comment Share on other sites More sharing options...
ilikeriding Posted May 12, 2007 Report Share Posted May 12, 2007 Nope i disagree Rock pads *** !! A grind is a better option but it does weaken you rim ! Its up to you really,want to have bout 4 weeks of good riding then buy a new rim. (tryall's will last bout 2 week)or keen putting tar on and have a rim until you want to change! Personaly i would rather have a month of good riding Ben(Y)You've ridden for 2 weeks, I dont know how you came to this conclusion. Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted May 12, 2007 Report Share Posted May 12, 2007 i run a grind over the winter months so i can ride without fear of brakes slipping,and in the summer i ride a dead grind with smooth rim pads (rock pads greens,zoo! pads ).steve Quote Link to comment Share on other sites More sharing options...
Muel Posted May 12, 2007 Report Share Posted May 12, 2007 (edited) I have a grind and citrus pads, its pretty crap really.Buy some smooth rim pads first, look on tarty for ones that are recommended for smooth rims and try them. It they arn't good enough, try some tar.I have never used tar by the way, but it sounds good.EDIT: BTW, 2 weeks for a Try-All rim is the biggest load of shite I have ever heard. They last for ages. If they only lasted for two weeks, no-one would have ever thought of drilling them would they?! Edited May 12, 2007 by KuelMuel Quote Link to comment Share on other sites More sharing options...
shansen Posted May 12, 2007 Report Share Posted May 12, 2007 its summer so leave it smooth when its winter grind your rim and and it should get less harsh by next summer again smooth rims for summer grind for winter its the way to go!! use thin layer of tar with both. Quote Link to comment Share on other sites More sharing options...
