Echo Rims
hay i told my freind that i want to get a echo 07 rim and he sed it wont fit but a try-all fits so do echo 07s rear fit in a t rex
Hi yes they do fit my mate had a t-rex with a 07 echo rim there fine.
also if you have 36 spokes you can't get one because they only come in 32 hole.
chris
yeah they do fit mate, dont see why not. if a try all can then so should an echo.
what was your friends reason why it wouldnt fit.
JK
he sed you will have to max the brake out and then it WONT BE THAT GOOD
chris
i am getting a new hub.
doesnt matter where the brake is it will still work as well.
however you will lose some adjusment but its nothing to worry about.
but if the rims are the same widh which according to tarty they are then it shouldnt matter at all
