Bootom Bracket Width Help
T.McMillan
my bottom bracket width is 113mm, and the cranks are pretty damn close to the chainstays either side, is the only reason for wider(118mm/128mm) bottom brackets for clearance on the chainstays or is there another reason im missing?
also which is better to go for? i would assume the 128mm because it will clear most frames, thats only if my reason is correct above?
HELP lol
tom
Edited by speedyjustice
