Onza-rider Posted May 8, 2007 Report Share Posted May 8, 2007 On my back magura i have rounded the bolt trying to bleed the brake. :$ does anyone know how to get the bolt out?cheers Onza-Rider Quote Link to comment Share on other sites More sharing options...
trialsrider101 Posted May 8, 2007 Report Share Posted May 8, 2007 saw or hamer and flat screwdriver to make a slit in the top of the bolt then you can use the fat headed screwdriver to take it out hope this works Quote Link to comment Share on other sites More sharing options...
Onza-rider Posted May 8, 2007 Author Report Share Posted May 8, 2007 saw or hamer and flat screwdriver to make a slit in the top of the bolt then you can use the fat headed screwdriver to take it out hope this worksgood idea cheers .i will try that . Quote Link to comment Share on other sites More sharing options...
Ryan Trott Posted May 8, 2007 Report Share Posted May 8, 2007 (edited) . Edited May 7, 2011 by Ryan Trott Quote Link to comment Share on other sites More sharing options...
Onza-rider Posted May 8, 2007 Author Report Share Posted May 8, 2007 You might be able to take it out with a torx bit. Simply hammer the torx bit into the allen key head and turn with a socket ( has to be slightly bigger than the original allen key was, obviously, to grip the inside of the bolt. )sorry i don't get you can you refrase it . :$ Quote Link to comment Share on other sites More sharing options...
missionmod Posted May 8, 2007 Report Share Posted May 8, 2007 sorry i don't get you can you refrase it . :$Basikly hes trying to say get a tork bit one size bigger then the bolt (that is rounded of ) hammer the tork bit in to the bolt so it sticks in, and undo the bolt.does that help? liam Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted May 8, 2007 Report Share Posted May 8, 2007 Glue an old/spare allen key into the bolt? Quote Link to comment Share on other sites More sharing options...
da_bomb_bikes Posted May 8, 2007 Report Share Posted May 8, 2007 if its a alan key bolt get a slightly bigger size *** in with a hammer dont saw off lol thnx . james Quote Link to comment Share on other sites More sharing options...
Grant H Posted May 8, 2007 Report Share Posted May 8, 2007 drill it out? Quote Link to comment Share on other sites More sharing options...
Mod Man Leo Posted May 8, 2007 Report Share Posted May 8, 2007 saw or hamer and flat screwdriver to make a slit in the top of the bolt then you can use the fat headed screwdriver to take it out hope this worksYeah , thats the best idea, Get a nice thin hack-saw and basicly in the middle of the bolt were the alan key hole is , just saw a dead straight hole on the bolt head, the thinner the better.Then just get a Flat head skrewdriver to unscrew it.Leo Quote Link to comment Share on other sites More sharing options...
Onza-rider Posted May 9, 2007 Author Report Share Posted May 9, 2007 Basikly hes trying to say get a tork bit one size bigger then the bolt (that is rounded of ) hammer the tork bit in to the bolt so it sticks in, and undo the bolt.does that help? liamCheers i get it now Quote Link to comment Share on other sites More sharing options...
