Echo Cnc Rim Brake
Do the new echo brakes live up to there price ?
They look nice and seem to have a more advanced spec, they have the same TPA adjustment to the Magura HS33 and neatly hidden away. The weight seems to be very light as well at only 311g per brake, including 4 bolt mounts. The magura is close at 315g per brake, including 4 bolt mounts. The magura was always the daddy of trials rim brakes. Has echo managed to knock it off its perch ? What you say ? The materials is also special fully CNC machined construction (not cast like other rim brakes) makes them super strong and stiff.
Magura or Echo *** ?
Ben
i'm sure there was a topic on this not so long ago :ermm:. i haven't tried them so i can't really say, but there not bad for the money as you get pads,bolts and nice cnc'd mountings and they also look really cool and different. i like my maggie and am sure alot of people would just stick with theres.
To be onest there not much differnt in wait. iv never tryed one but, from what iv read they seem good as they are smaller and bit stonger. But basikly you pay alot more for not that much differnts apart from about 4grams in wait. but that my opinon . is up to you .
Yer i agree, they have reveiws that say they have amazing stopping power. I think the maggies are still better though :D
Ben
Ben
I your thinking about buying them,i would just stick with maggies they basikly just as good and you save a lot more money
liam (Y)
If you look on tarty, a the avid ultimate lever for vee's is more expensive than a full maggie.
JK
Yer i saw that, is there a reason why ?
Ben
- As favoured by many trials riders from all across the world, Avid's Ultimate brake levers sit at the top of their product range and rightly so!
- Full CNC machined construction ensures the best possible stiffness and strength, while still making the levers as light as they are pimp!
- Relatively large lever blade is nicely rounded for a very comfortable feel.
- Patented adjustable leverage allows on-the-fly adjustment without tools, meaning the rider can dial in the exact feel and performance they want.
- Lever pivot runs on two sealed cartridge bearings to ensure the lever doesn't develop play and runs extremely smooth!
- Split lever body clamp makes removal and fitting much easier than having to remove your grips!
- Stealth black anodised finish with highly detailed laser etched logos.
- Weight: Only 76 grams!
That is a amazing lever :P
Ben
Ben
Ben
Well for one look at the weight of it !. i run a front vbrake and its never let me down.(until today as i broke it lol ) but anyway vbrake can be very powerful brakes as longs they are set up right.
liam
So what you planning on doin ? gettin another vee or gettin maggie/disk ??
Ben
well im geting a proper old school frame seen of one of me feinds. zoo lynx and might get some new forks as well so think about a disc, but il probil just stick to me vees as its all ways worked and easy to fix if anything goes wrong.
liam
