My Pythong
The Duck
spec...
Frame: Python '07 (thanks craig)
Forks: Echo Lite '06
Front brake: Spanking new '06 Mono Trial
Rear Brake: Maggy with zoo pads
Front wheel: Onza disk hub (soon to change), drilled hog rim
Rear wheel: Profile hub (thanks wheeler ;) ), Try-All rim, medium grind
Stem: Echo Team
Bars: Zoo!
Cranks: Echo 7075
Bash ring: Echo 7075
Bits and bobs... Chain: KMC, Snail cams: Zhi, Tyres: Creepy Crawlers, Front Skewer: Hope, Front sprocket: Zhi, Pedals: DMR V8s...
Edit: Weighing in at under 21.2lbs!!
Your opinions s'il vous plaît!
xx
Edited by Quackers
That be reeeet man with some tension on your chain.
The chain now has tension :turned:. I'd just slapped the wheel on and i was so chuffed with the way it looked i took pictures before i even had a go!
thats well nice mate...so its the short one then ?
phill
I don't think so... Tarty measure the short one at 1030mm and the long at 1045. Mine is 1037, smack in the middle. Don't really understand but it rides so, so nicely....
  • 1 month later...
looks sweet man i dont know whether to take the stickers off mine
you must have the short or really bent forks
i know mines the long just went and measured is and it is bang on 1045 center of bolt to center of bolt
still looks sweet though man
nick
