Re Using Spokes
Nick Garland
I have at the moment an echo 2007 front rim on a pro 2, I have a new echo 2007 front rim that I am going to build onto the pro 2 so its the exact same wheel. I have had the old one together for 5 months now will the spokes be ok to re-use or shall I get some new ones?
I have been using a front disc but the tension has not been really tight as I have been scared of ripping the nipples through my rim so the spokes should not be too stressed.
I did a mixture of the above before even reading this. I losened all the non disc ones, moved them over and put the nipples on losely but enough to hold them in place, did the same for the disc side.
Then the usual of tensioning, truing, dishing etc, worked a treat.
