alex_jsy Posted May 5, 2007 Report Share Posted May 5, 2007 I was having a problem with my rear innertube puncturing the other day and couldn't understand whyits one of those monty 19" by 2.6 inner tubes and i would expect it to be holding up much better than it waswhen i took the tyre off i saw the inner tube was a thin cheng shin 20" x 2.125is this monty just trying to rip people off charging a few extra quid for an inner tube that isn't designed to fit a wide tyreor can the spanish not count or sumthing?? Quote Link to comment Share on other sites More sharing options...
Si-man Posted May 5, 2007 Report Share Posted May 5, 2007 You probably ordered the wrong one. Quote Link to comment Share on other sites More sharing options...
alex_jsy Posted May 5, 2007 Author Report Share Posted May 5, 2007 haha no chance man it came in a monty box Quote Link to comment Share on other sites More sharing options...
ManxTrialSpaz Posted May 5, 2007 Report Share Posted May 5, 2007 (edited) I had Cheng Shin tube in a monty box off Tarty. Think it was the same size (as the monty spec), not sure, either way, it's in my bike now Edited May 5, 2007 by ManxTrialSpaz Quote Link to comment Share on other sites More sharing options...
Up'n'away Posted May 5, 2007 Report Share Posted May 5, 2007 Take it out, put it in a bowl of half boiled kettle water for about 5 mins then put it back in and try it. Quote Link to comment Share on other sites More sharing options...
Grant H Posted May 5, 2007 Report Share Posted May 5, 2007 Take it out, put it in a bowl of half boiled kettle water for about 5 mins then put it back in and try it.what exactly will that do? Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted May 5, 2007 Report Share Posted May 5, 2007 get it wet and luke warm by the sounds of it Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted May 5, 2007 Report Share Posted May 5, 2007 I just use normal Halfords 20" tubes.Fit fine, just have to pump it more so it expands out in the big tyre.. Quote Link to comment Share on other sites More sharing options...
Grant H Posted May 5, 2007 Report Share Posted May 5, 2007 get it wet and luke warm by the sounds of itwhats the point in that? Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted May 6, 2007 Report Share Posted May 6, 2007 you obviously havent read the topic at all so shut it Quote Link to comment Share on other sites More sharing options...
Grant H Posted May 6, 2007 Report Share Posted May 6, 2007 you obviously havent read the topic at all so shut itah right so it changes a thin cheng shin 20" x 2.125 into a monty 19" 2.6 inner tube? Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted May 6, 2007 Report Share Posted May 6, 2007 tit Quote Link to comment Share on other sites More sharing options...
Si-man Posted May 6, 2007 Report Share Posted May 6, 2007 It warms it up allowing the tube a little more give so when pumped up, it expands more.If you still dont get it then there is no hope for you Quote Link to comment Share on other sites More sharing options...
Luano Posted May 6, 2007 Report Share Posted May 6, 2007 this is a thread about innertubes...why? Quote Link to comment Share on other sites More sharing options...
Si-man Posted May 6, 2007 Report Share Posted May 6, 2007 If you read the first topic you will know why. Quote Link to comment Share on other sites More sharing options...
Grant H Posted May 6, 2007 Report Share Posted May 6, 2007 It warms it up allowing the tube a little more give so when pumped up, it expands more. cheers for actually explaining Quote Link to comment Share on other sites More sharing options...
T_PRO Posted May 8, 2007 Report Share Posted May 8, 2007 I get my front inner tubes from halfords and my rear inner tubes from Supercycles. Never really had that much of a problem with my inner tubes, expect the front tends to punchure more than the rear. Quote Link to comment Share on other sites More sharing options...
