Boswell Posted May 3, 2007 Report Share Posted May 3, 2007 (edited) I have just got a new set of cranks( Echo 7075, tryall BB and Czar bashring) but i can remove the drive side of my old muscleman cranks. The extraction thread has been ripped out and i have tried bashing it. Any ideas Edited May 3, 2007 by mr ? Quote Link to comment Share on other sites More sharing options...
trialsrider101 Posted May 3, 2007 Report Share Posted May 3, 2007 do you want the chainring anymore if not turn the bike upside down and hit the arm in several different directions then one big swing and it should come offtom 1 Quote Link to comment Share on other sites More sharing options...
Boswell Posted May 3, 2007 Author Report Share Posted May 3, 2007 (edited) do you want the chainring anymore if not turn the bike upside down and hit the arm in several different directions then one big swing and it should come offtomYes i do want my freewheel and i have already explained above that i have tried to bash it. thanks anyway. Edited May 3, 2007 by mr ? Quote Link to comment Share on other sites More sharing options...
trialsrider101 Posted May 3, 2007 Report Share Posted May 3, 2007 ok you could always put a big spanner down the side of it and try and push it out 1 Quote Link to comment Share on other sites More sharing options...
Boswell Posted May 3, 2007 Author Report Share Posted May 3, 2007 ok you could always put a big spanner down the side of it and try and push it outI doubt i will be able to push it out when it isn't budging a millimeter when i am hitting it with a hammer. Quote Link to comment Share on other sites More sharing options...
Grant H Posted May 3, 2007 Report Share Posted May 3, 2007 saw the bb axle off Quote Link to comment Share on other sites More sharing options...
trialsrider101 Posted May 3, 2007 Report Share Posted May 3, 2007 I doubt i will be able to push it out when it isn't budging a millimeter when i am hitting it with a hammer.worth a shot though 1 Quote Link to comment Share on other sites More sharing options...
Boswell Posted May 3, 2007 Author Report Share Posted May 3, 2007 worth a shot thoughNo it isn't. Quote Link to comment Share on other sites More sharing options...
James Quigley Posted May 3, 2007 Report Share Posted May 3, 2007 just ride around without a crank bolt in and it should loosen up Quote Link to comment Share on other sites More sharing options...
Boswell Posted May 3, 2007 Author Report Share Posted May 3, 2007 just ride around without a crank bolt in and it should loosen upIm sure you mean out....Anyway, i have had the bolts out for a good few weeks now and only the non drive side has come off, the drive side just will not budge! Now to top it off i think the tapper on the non drive side is rounding off. Arrrrr Quote Link to comment Share on other sites More sharing options...
paul@rettotrials Posted May 3, 2007 Report Share Posted May 3, 2007 hit it like your trying to kill it, it will work trust me. Quote Link to comment Share on other sites More sharing options...
Grant H Posted May 3, 2007 Report Share Posted May 3, 2007 soak it in WD-40then wack it Quote Link to comment Share on other sites More sharing options...
James Quigley Posted May 3, 2007 Report Share Posted May 3, 2007 lol, yeah I did mean out, having it in will do no good.Well when my middleburns got stuck on the bb, I full on 'SMACKED' them with a giant lump hammer for a good 15 minutes, they soon came off, although my hand was dead from the vibrations, and my crank arm looked like a squased turd, point is it came off Quote Link to comment Share on other sites More sharing options...
abe Posted May 3, 2007 Report Share Posted May 3, 2007 heat the crank arm. I used a hair dryer type thing my dad uses for work ( obviously more heat than a hair dryer). the metal expands, then basically do all the above and it will come of in a good 5 minutes, providing you heat it up enough. Quote Link to comment Share on other sites More sharing options...
Boswell Posted May 3, 2007 Author Report Share Posted May 3, 2007 What could i use to heat it? Quote Link to comment Share on other sites More sharing options...
Grant H Posted May 3, 2007 Report Share Posted May 3, 2007 What could i use to heat it? blow torch Quote Link to comment Share on other sites More sharing options...
Boswell Posted May 3, 2007 Author Report Share Posted May 3, 2007 blow torch Dont really have access to one Quote Link to comment Share on other sites More sharing options...
Grant H Posted May 3, 2007 Report Share Posted May 3, 2007 (edited) Dont really have access to one deoderant and a lighter Edited May 3, 2007 by Grant H Quote Link to comment Share on other sites More sharing options...
Boswell Posted May 3, 2007 Author Report Share Posted May 3, 2007 deoderant and a lighter Are you f*cking crazy. Quote Link to comment Share on other sites More sharing options...
harmertrials Posted May 3, 2007 Report Share Posted May 3, 2007 I heated mine with a welding blowtorch until they were red hot, then continued to hit the hell out of it with a punch and a metal sledge hammer, it still didn't come off even after a whole day of trying. I gave up. Quote Link to comment Share on other sites More sharing options...
Grant H Posted May 3, 2007 Report Share Posted May 3, 2007 Are you f*cking crazy. thats some way of putting it...If you dont want to keep the bb just saw the axle off on the drive side Quote Link to comment Share on other sites More sharing options...
grantallsop Posted May 3, 2007 Report Share Posted May 3, 2007 Why not use a crank puller and then a freewheel remover(Y) Quote Link to comment Share on other sites More sharing options...
Grant H Posted May 3, 2007 Report Share Posted May 3, 2007 Why not use a crank puller and then a freewheel remover(Y)because all the threads are stripped, as he said before Quote Link to comment Share on other sites More sharing options...
harmertrials Posted May 3, 2007 Report Share Posted May 3, 2007 Why not use a crank puller and then a freewheel remover(Y)Because the thread has gone in the crank, as mine did. Quote Link to comment Share on other sites More sharing options...
2sixstreet Posted May 3, 2007 Report Share Posted May 3, 2007 Put the non drive side crank back on but at 180 degrees to how it is supposed to be. It will be facing the same way as the drive side. Put the crank bolt in and do it up. Make sure the bolt is removed from the drive side. Get a car jack/small bottle jack/jaws of life in between and get cranking. Quote Link to comment Share on other sites More sharing options...
