jayz_ Posted April 29, 2007 Report Share Posted April 29, 2007 was on supercycles.co.uk and they had for saleT-Comp Pro Speccould someone just tell me the difference, if there is any between this one and an ordinary T-Compthanks in advancejayy_ Quote Link to comment Share on other sites More sharing options...
Bearded Midget Posted April 29, 2007 Report Share Posted April 29, 2007 i reckon it is the same geometry because the t pro and t comp are basically the same bike apart from weight difference.stick with the normal t comp because the t pro costs less than the t comp so therefore using t pro parts on a t comp just reduces its quality Quote Link to comment Share on other sites More sharing options...
jayz_ Posted April 29, 2007 Author Report Share Posted April 29, 2007 so why does it cost the same price? Quote Link to comment Share on other sites More sharing options...
poopipe Posted April 29, 2007 Report Share Posted April 29, 2007 (edited) edit::ok, got confused. it's most likely an old style t-comp frame - NOT the 07 t-comp, which is actually a t-pro frame. Edited April 29, 2007 by poopipe Quote Link to comment Share on other sites More sharing options...
jayz_ Posted April 29, 2007 Author Report Share Posted April 29, 2007 (edited) so is that good or bad?and also, HS33 or Hydraulic only and not V-brake.. right? Edited April 29, 2007 by jayz_ Quote Link to comment Share on other sites More sharing options...
poopipe Posted April 29, 2007 Report Share Posted April 29, 2007 so is that good or bad?and also, HS33 or Hydraulic only and not V-brake.. right?good/bad depends on your point of view.they're short and very light but they look stupid and aren't really up to being bashed into walls . I'd say this... the t-lite would be good if you like short framesthe zona if you like long framesthe t-pro if you aren't sure if you like short or long (plus you've got enough change for some new forks that don't weigh a metric tonne with this one)hs33 are indeed hydraulic - the spec seems to be the 05 / 06 t-pro spec which is more like the 07 t-comp spec than the 07 t-pro spec Quote Link to comment Share on other sites More sharing options...
jayz_ Posted April 29, 2007 Author Report Share Posted April 29, 2007 "hs33 are indeed hydraulic - the spec seems to be the 05 / 06 t-pro spec which is more like the 07 t-comp spec than the 07 t-pro spec"wouldnt i need to get new brakes as apparently v-brakes arnt that good for trials Quote Link to comment Share on other sites More sharing options...
poopipe Posted April 29, 2007 Report Share Posted April 29, 2007 (edited) "hs33 are indeed hydraulic - the spec seems to be the 05 / 06 t-pro spec which is more like the 07 t-comp spec than the 07 t-pro spec"wouldnt i need to get new brakes as apparently v-brakes arnt that good for trialsv brakes are fine when set up right but since none of those bikes come with v brakes it's not an issueeverything on this page looks to be old spec and therefore has HS33 brakesjust so you know this is an old t-compIt's pretty difficult to figure out what the hell's going on with the supercycles site - I dont reckon they look at it all that often, let alone update it Edited April 29, 2007 by poopipe Quote Link to comment Share on other sites More sharing options...
