Magura Fluid
adamant_a2
I just bled mine with WD40 a few nights ago.
Had water in it, but the lever piston needed servicing, so I washed it out with WD40, then just thought it's easier to have WD40 in the system all the time.
Just took a while to get all the bubbles out of it when I sprayed it into the syringe...
Johnson's baby oil, water, alcohol, etc...
Any mineral oil will do you, for a snappier lever feel just fill your brake with lighter oil and it'll be reet.
Water owns though but it does freeze, even with a bit of anti-freeze in it so beware.
i bled mine with wd40 the other day aswel, i sprayed it into a little pot and sucked it into the shringe
but i took my bike out today ofter not using it for a couple of days and it took a few pups to get going but aftrubbish there was er that it was hardly any bite and hardly any hold so i was not a happy bunny lol (N) so i think a re-bleed is in order tomorrow i may use water i havent decied yet lol i will sleep on it lol
bit of a warning if you are going to use wd40, mine felt mint after i bled it so i don't know lol
Liam (Y)
  • 4 weeks later...
  • 9 months later...
i live in Glasgow which is cold as fook as far as the uk goes and have had the same water bleed for nearly a year and its still the business. Just go and do it im telling you, makes your brake feel so light.
