Initial Design Ideas For A Level Tech Bike Frame!
NVWOCI WVS
QUOTE(Bill_B @ Apr 26 2007, 02:23 PM)
what type of brakes are you intending to use, Disc, Rim, Vee? and what size wheels will it have?
a magura mounted underneath the frame if you get me? 26inch wheels.
365 backend will be awful, 375 minimum, 380 is perfect and 385 aint bad
this is still the very first prototype/initial idea so geametry is kindof academic at this stage, its just the principal of the idea im working on...but i reckon 385mm will be what i probably end up with.
why does the downtube come out the arse end of the BB shell?
That just decreases clearance and add's weight why can't you weld the stay's directly to the bbshell?
i figured this ,might make it stronger as there is more area to braze the chainstays to? probably wrong but at the moment this is all just ideas! not even started the project officiaklly yet, just had this as an idea...definitely making a frame, just coming up with some design ideas!!
