Internet Conection Help
trials_pimp
right, got a wireless card for my mothers computer.
Got it instaled ok, with all the latest drivers ect.
everything seems to work fine, it can find our home network, with excellent signal sterngth ect.
but when you try and connect, it just sits on aquiring network address, doesnt go any further.
tried all the network and wireless wizards on windows and its just the same.
what do i need to do to get this computer online??
(i know it works fine online, its my old comp)
Ok there are lots of possible things it could be, so first heres a search link for setting up a wireless connection/network.
Wireless Networks
But this is what I would do:- Most routers enable you to log on to it to set up security and the like, so do that.....usually something like 192.168.0.1 (type into your internet address bar)
password is normally User:- admin, Password:- admin
Then check your security settings, see if there is a WAP key...this protects your network from muppets who want to piggy back your connection.
If it has a key then this needs to be setup on your mums comp, if not then you might find it better to manually set up the IP on this wireless adapter.
Go :- START (bottom left) CONTROL PANEL - NETWORK CONNECTIONS - and find your wireless one, right mouse click it and look for network settings....
you are looking for TCP IP settings, or telling it to use the following IP.
you need to know your router IP.....its the same number you use to connect to it, then you can give the wireless adapter an IP (this saves it looking for one)
So you IP has to be the same range....i.e. ROUTER is 192.168.0.1 (your i.p. 192.168.0.2) or if your router is 192.168.1.1 then your I.P would be 192.168.1.2
This is what you should end up with.
You will have to select (Use the following IP address)
IP - 192.168.0.2 (depends on your router IP range)
Subnet - 255.255.255.0
Gateway - 192.168.0.1 (this is your router IP)
default DNS - 192.168.0.1 (this is your router IP)
hope this makes sense.
all that
and
check if DHCP is enabled on the router.
if DHCP is not enabled you need to assign an actual IP address to the wireless card in the problem computer (a different one from the other machine obviously) . it'll also need the DNS set up - either as lego said or just point it straight at your ISP DNS server - it depends on your exact setup.
if DHCP is enabled then make sure the problem computer has everything set to automatic in it's connection settings
right, cheers lego, that got me connected.
But now its really slow, only conected at 24Mbps (sisters laptop connects at 56, and seems almost as fast on conection as my desktop) and doesnt want to load any pages.
Also windows update seems to have stopped at 28% and wont go further.
what sort of speed should i expect, home broadband is 4mb (last time i checked).
Ok the speed you`re seeing is from the wireless computer to the router, not your available download speed...if that makes sense....heres an example.
My download speed max is 4mg, but my local area network (LAN) is 100mps
Most wireless devices will produce varying speeds dependent upon what hardware is used, if you can list me what you have I.E - router and wireless cards/sticks.
But standard wireless adapters offer speeds from 11mps up to I think 125mps (newer stuff). So for you to have to different adapters that have different speeds is normal.
I won`t be on now until about 6ish...got to go do some work.
ok.
i have got.
NTL broadband modem
going to netgear wireless router.
my desktop is running directly from the router, via cable.
sister has dell inspiron 1300 laptop
and mothers desktop has a MSI wierless card.
seems to be connecting to the netwrk, says its all connected and ready, got data being recived and sent but will not connect to internet.
Ok which of the machines cannot connect to the internet....give me IPs and the manufacture info for wireless adapters.
Plus I`am on NTL....sign up and check here NTL/Virgin Media Forum
P.S:- GO > START > RUN > type CMD > type PING WWW.YAHOO.CO.UK > press enter
if it can ping outside your house it can get on the internet.....its NTL...if it don`t ping outside its inside :) simply logic is best :)
if you're on the wireless network but can't get on the interweb it's most likely that you don't have the right DNS set up.
go on the machine that can connect, open a command prompt and give it the old "ipconfig /all", copy the ip addresses from the DNS entries that it shows you and put them in the machine that doesn't connect's wireless network settings jibber.
the difference in speed is probably down to a crappy wireless connection - try wiggling the ariels or moving nearby metal objects
Edited by poopipe
ok.
i have got.
NTL broadband modem
My friends did that, seems IE had kept the old settings and wouldn't find the new ones. Installing firefox got him browsing the internet again till IE7 came out and now he can use either.
Might be quicker to try that on the off-chance it might work than to go through settings and fiddle with them.
Try that see if it works and tell us what the result is. Also check the security settings see if its got "ALLOW BY MAC ADDRESS" ticked. Only people on this list can access the internet.
P.S. Mac address is the ident number for that piece of wireless hardware.
