Rear Break Slipping
Rebelistic
I've had koxx red pads for a while with a ground tryall rim. All seemed pritty good.
I replaced my rim with a new one and ground it - it seemd good for a while (a couple of weeks), then performance dropped (didn't hold aswell + didn't squeak).
I've re-ground the rim (and the pads) again and it worked well for about a day and then performance dropped again.
Any ideas why this may be happening? - Could it be my grinder disc getting warn and not grinding very deep?
The break pads are quite warn down but still have plenty of material left.
Thanks for your help,
John (Y)
The break feels solid enough so I guess it doesn't need bleeding and I do use a booster.
I think I'll have to try a new disc for the grinder or maybe some different pads - I'm pretty sure the problem is not enough friction between pads and rim.
Untill then I'll have to pull the lever harder :lol:
Cheers (Y)
Before you buy anything, take a hack saw to your grinding disc and cut a few slots around it at say 2 cm intervals around the circumferance, that's what's I do when my grinds are getting a bit shitty and it usually helps.
I'm not trying to be funny, and I know this doesn't help you, but this is why I don't bother with a grind. I read about more people having problems with grinds/pads/rim materials/stone disks/metal disks etc, than I do with people using any smooth rim with a little tar.
Seriously, what the point? Use tar IMO!
It rained today, yesterday and sunday.
Mat
Hi, thanks for the replies (Y) - I meant to reply sooner but couldn't get on an XP PC.
Jon mate, its Boumsong and Krisboats, we recommend new pads, maybe plazzmatics or Alic C joyoads..or even rock greens...
ps, we've nbeen down the opub, will literatew this on th emorning..
Yeah I think I'll get some new pads - I don't care how fast they wear, as long as they perform well.
Although koxx reds are supposed to be good though?
Is that safe? - I can imagine the disc shattering.
I got a diamond cutting disc with the grinder, I could try that - don't want to slice through the rim though :lol:
I do sometimes ride in the wet so smooth rim with tar's not the best option.
I'll have to get something sorted out soon as I find riding with a good break so much easier.
Cheers,
John (Y)
