Computer Problem Please Look In
Conor the basher.
Right basically i have a phillips x55 and i need to to a system recovery becuase it wont start but it will not run then disc it just starts up asked me how i want to run the compuer IT DOSE NOT WORK IN SAFE MODE LOL then just goes to the thing where it says windows and that little green things keeps going past then it concks out, i no there is a way where i can start it then press somthings what take me in to a main control thing
(did it on a other comp) and can changes the way my computer start so it will start by reading the disc bit i CANT rmember how do any of you ??????
cheers conor any info would be amazing.
Starting in safe mode is usually enabled by pressing f8 during the posting screens (black and white writing before what you described as "the thing where it says windows and that little green things keeps going past")
Should give you a list of options, choose safe mode and it should boot up into safe mode with no running programs and limited networking options. This way you can do a virus scan or remove a piece of software that caused the big windows cock up.
To enable the BIOS (main menu of the computers settings) pressing something like Del, F2, F10 etc should jump you into it. It should say on the screen when you first turn it on something along the lines of "press (insert button here) to enter setup".... basicaly just hit that button.
You then want to navigate to the boot devices and enable the cd/dvd drive as the first boot option, if that doesn't seem to work set them all to cd/dvd drive.
If it doesn't work, post up again and we'll go from there.
P.S. Your DVD should turn up tomorrow for you ;)
Money is being sent today as i totally forgot got it writen on my hand and every thing :)
Right basically i got in to the bois and i changed the start up assistant to the cd/dvd drive bit it still will not read the disc i think its because the recovery disc is also a manual aswell , so i have changed it back to the original setting and pc world here i come. its still on warranty so it shoul be ok but thanks for you help i will post up if i have any more problems.
cheers for your help conor :):)
