echo_897 Posted April 23, 2007 Report Share Posted April 23, 2007 hi all just wondering is it any way possible to put a dmr revolver onto a bmx? Quote Link to comment Share on other sites More sharing options...
poopipe Posted April 23, 2007 Report Share Posted April 23, 2007 hi all just wondering is it any way possible to put a dmr revolver onto a bmx?not if it has stock spacing Quote Link to comment Share on other sites More sharing options...
SomeoneNew Posted April 23, 2007 Report Share Posted April 23, 2007 Erm don't think so the revolver has mtb(135) spacing and BMX's are the same as mods are they with 116 or something like that! Quote Link to comment Share on other sites More sharing options...
poopipe Posted April 23, 2007 Report Share Posted April 23, 2007 Erm don't think so the revolver has mtb(135) spacing and BMX's are the same as mods are they with 116 or something like that!110mm but yeah.in that case noalso - if your bmx isn't ancient (or for flatland) then the slots in the dropouts will be for 14mm axles which the hub won't have either. Quote Link to comment Share on other sites More sharing options...
echo_897 Posted April 23, 2007 Author Report Share Posted April 23, 2007 surely u could put washers in so it would go in a 14mm frameisen,t their any solution or bodge more spacers longer bolts etcanyone??? Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted April 23, 2007 Report Share Posted April 23, 2007 dont they make a bmx version to fit the transition frame? or is that just mtb spaced 14mm axle? Quote Link to comment Share on other sites More sharing options...
poopipe Posted April 23, 2007 Report Share Posted April 23, 2007 surely u could put washers in so it would go in a 14mm frameisen,t their any solution or bodge more spacers longer bolts etcanyone???you can get 10-14mm adaptors but it wont change the fact that the hub is 25mm too wide for the frame. Quote Link to comment Share on other sites More sharing options...
echo_897 Posted April 24, 2007 Author Report Share Posted April 24, 2007 ok cheers for the replies anyway guys. Quote Link to comment Share on other sites More sharing options...
flas12345 Posted April 25, 2007 Report Share Posted April 25, 2007 i have a profile 26" hub built onto a onza rim and its fine so i dont see why not.cheers lou. Quote Link to comment Share on other sites More sharing options...
SomeoneNew Posted April 25, 2007 Report Share Posted April 25, 2007 the profiles have bmx spacing not mtb don't they? theres no way you could fit an mtb hub into a mod/ bmx dropouts without machining the hub body down or stretching your dropouts apart at which point they'd probably fall off cos 25mm is a long way! Quote Link to comment Share on other sites More sharing options...
poopipe Posted April 25, 2007 Report Share Posted April 25, 2007 they do profiles in both sizesstock spacing is 135mmbmx spacing is 110mod spacing is generally 116mm so you can fit the snail cams in around a bmx sized hub Quote Link to comment Share on other sites More sharing options...
