Car Stereo Wiring!
Ducko
rightio, good day.
i have just bought a head unit for my car an im putting my new speakers in this weekend,
only problem is due to my car being old i have had to buy a diffrent wiring loomy thing for the back,
but this means i no longer have the remote on lines out for my amp.
is there any other way i can cut of the power to the amps without unboltng the power leads from either the battery or the amp.
cheers!
rightio, good day.
cheers!
not sure i follow you mean the adapter lead(iso> manufacturers spec) doesnt have a remote cut off for your amp on it, so youve got the remote out for your amp from your headunit, but then it goes no where, as thats all i think you can mean.
in which case just run a wire from your remote cut off on the head unit, to the remote cut off on the amp, job done.
it does have the remote lead on the original wireing loom that coems with the head unit,
but i had to buy an older style one to fit my old b*****d car, this one doesnt have the remote lead.
sorry hard to explain.
ok think i get you, right then, get the original wiring loom that coms with the head unit, and the new wiring loom, look at the remote out lead. on the original wiring loom, note which pin it connects to, then on the new wiring loom, either fit the pin/wire from the original loom, or if theres a pin there, but no wire, just run a wire off it.
