shogun_gimp Posted April 23, 2007 Report Share Posted April 23, 2007 Hey my front brake it fairly squeeky when i apply it.... the bike it only a week old... the brake is a V-Brake... has this happened to anyone else and if so how did you solve it Thanks Quote Link to comment Share on other sites More sharing options...
simtradan Posted April 23, 2007 Report Share Posted April 23, 2007 If the brake works allright then does it really matter about the sound. Just wait for the pads to bed in a bit, if your rims are smooth then it might be an idea to go over them with a bit of sand paper. Quote Link to comment Share on other sites More sharing options...
nmt_oli Posted April 23, 2007 Report Share Posted April 23, 2007 Is the rim clean? as contaminants can cause brakes to squeek, as does puttign tar on.You may also want to toe in the pads slightly. this means you dont set the pads up dead flat with the rim, but set them so that the front of the pad hits the rim just before the back (i use a credit card under the back of the pads to get it the same on both sides).this helps reduce vibration, and noise. 1 Quote Link to comment Share on other sites More sharing options...
shogun_gimp Posted April 23, 2007 Author Report Share Posted April 23, 2007 Is the rim clean? as contaminants can cause brakes to squeek, as does puttign tar on.You may also want to toe in the pads slightly. this means you dont set the pads up dead flat with the rim, but set them so that the front of the pad hits the rim just before the back (i use a credit card under the back of the pads to get it the same on both sides).this helps reduce vibration, and noise.Well the rim has like the rubber of the brake pads then i wiped it of but it was still there.... ok ill try and toe it in thanks! Quote Link to comment Share on other sites More sharing options...
RR_Trials Posted April 24, 2007 Report Share Posted April 24, 2007 Dude, calm down on all the threads these are all question you could have asked me on MSN. Anyway, it is good for brakes to squeek gives more confidence. When you come out and ride with me and Ryan you will hear real brake squeek Quote Link to comment Share on other sites More sharing options...
jandamna Posted April 24, 2007 Report Share Posted April 24, 2007 hehe, you really shouldnt worry about break squeek, i think we all get it, it should go away after about a week or two once the pads have worn down abit./jan Quote Link to comment Share on other sites More sharing options...
JT! Posted April 24, 2007 Report Share Posted April 24, 2007 A squeaky brake is a working brake. Quote Link to comment Share on other sites More sharing options...
ryan360 Posted April 24, 2007 Report Share Posted April 24, 2007 Its probably just the brake pads because ive replaced brake pads before and they have squeeked they might just need wearing in a bit. Quote Link to comment Share on other sites More sharing options...
T_PRO Posted April 24, 2007 Report Share Posted April 24, 2007 Once, I applied some of that Monty brake spray a bit too much and the next day my brakes were so noisy I had to go back home. But yeah, try using sandpaper to take off a layer of the pads. Quote Link to comment Share on other sites More sharing options...
