Z o o !! Posted April 22, 2007 Report Share Posted April 22, 2007 Thinking of doing a rim grind and was wondering how you do it? cheers connor Quote Link to comment Share on other sites More sharing options...
max-t Posted April 22, 2007 Report Share Posted April 22, 2007 (edited) 1) Get some money2) go to Argos3) purchase an angle grinder4) take it home5) get your wheel6) plug in the grinder7) put on some goggles8) turn the switch on9) pick up the grinder10) skim it along the surface of the rim11) keep doing this till all of the rim is rough12) turn the wheel over13) do the same on the other side14) turn the swtich off15) remove the grinder plug from the socket16) remove your goggles17) watch out for wires on the way out so you dont trip over Edited April 22, 2007 by max-t Quote Link to comment Share on other sites More sharing options...
Z o o !! Posted April 22, 2007 Author Report Share Posted April 22, 2007 1) Get some money I- have money2) go to Argos- Dont need to3) purchase an angle grinder- I alredy have 14) take it home- Dont need to5) get your wheel6) plug in the grinder- im not stupid7) put on some goggles- would be a good idea8) turn the switch on- im not stupid9) pick up the grinder- no shit sherlock10) skim it along the surface of the rim11) keep doing this till all of the rim is rough12) turn the wheel over13) do the same on the other side - no shit sherlock14) turn the swtich off- not that stupid15) remove the grinder plug from the socket- no shit sherlock16) remove your goggles- nah rather wear them there kinda trendy17) watch out for wires on the way out so you dont trip over- im not stupid Quote Link to comment Share on other sites More sharing options...
max-t Posted April 22, 2007 Report Share Posted April 22, 2007 1) Get some money I- have money2) go to Argos- Dont need to3) purchase an angle grinder- I alredy have 14) take it home- Dont need to5) get your wheel6) plug in the grinder- im not stupid7) put on some goggles- would be a good idea8) turn the switch on- im not stupid9) pick up the grinder- no shit sherlock10) skim it along the surface of the rim11) keep doing this till all of the rim is rough12) turn the wheel over13) do the same on the other side - no shit sherlock14) turn the swtich off- not that stupid15) remove the grinder plug from the socket- no shit sherlock16) remove your goggles- nah rather wear them there kinda trendy17) watch out for wires on the way out so you dont trip over- im not stupidTo be honest, if you were not stupid you would not be asking how to grind a rim. Use your Head. Quote Link to comment Share on other sites More sharing options...
mr_malcolm Posted April 22, 2007 Report Share Posted April 22, 2007 so really you knew how to do it then?hrmmmalthough i have to say i do like max awnsermade me chukkle a bit have fun grinding your rims down matei need to mine again soon havent done it for ages. Quote Link to comment Share on other sites More sharing options...
Onza-Trials Posted April 22, 2007 Report Share Posted April 22, 2007 you grind it the oppisite way the wheel turns if you do it the same way new rim for you to be honest . . . n do it till its rough both sides so preet straight foward Quote Link to comment Share on other sites More sharing options...
gu_lew Posted April 22, 2007 Report Share Posted April 22, 2007 (edited) have a few practise goes on some old non-expensive rims! i thought i would grind my rim, i had a few practise goes on some old rims and im glad i did lol i sucked at first. o yeah and remember to get some plazmatics or rock pads or you will just ruin zoo pads ect. Edited April 22, 2007 by gu_lew Quote Link to comment Share on other sites More sharing options...
Apocalypse_reaper666 Posted April 23, 2007 Report Share Posted April 23, 2007 i prefer the cross-grind, so virtually going back and forth every 4 inches with the grinder at a tilt from the rim. plus im using plazmatics on the left and rim-jams on the right and the grind hasnt worn out for the past 8 months. Quote Link to comment Share on other sites More sharing options...
fyfey Posted April 24, 2007 Report Share Posted April 24, 2007 Here's a small vid of someone grinding their rim iAtdLzUZyT0Fyfey Quote Link to comment Share on other sites More sharing options...
RR_Trials Posted April 24, 2007 Report Share Posted April 24, 2007 Very good ^^I need to get grinding. Quote Link to comment Share on other sites More sharing options...
JJ'S 24SEVEN Posted April 26, 2007 Report Share Posted April 26, 2007 Why grind the rim, there is no point. Quote Link to comment Share on other sites More sharing options...
Dekes Posted April 26, 2007 Report Share Posted April 26, 2007 (edited) Putting your wheel into a clamp with the axle will fix the wheel real nice so you can work easily and turn the wheel. You should put something around the axle not to damage it, i use a rag but you can also use a specific axle holder to put in a clamp. Parktool makes some in different forms.Cheers. Edited April 26, 2007 by Dekes Quote Link to comment Share on other sites More sharing options...
