Need Help On Moving Hops
shogun_gimp
Hi, People. I jsut joined the forum and just realy started riding. I can back hop ok but when coming to move in the hop (you know move forwards) i can`t, but instead either wheely or flip it. Is there anyone who can give me a easy way of starting doing it or how to do it. Hope you know what i mean :D
Thanks for the help.
its basicaly all rythem mate, you need to out your comftorbal foot forwards wheelie to the backwheel then just get the rythem of pushing your foot forwards and hopping at the same time. if you feel like your going to fall off keep your feet on the pedals till you absolutly have to to take them off, k mate hope i helped (Y) .
Thanks but when i put the brake on the bike front wheel hits the floor because im up oon the back wheel hopping then when i try i wheely then i got to balance then i put the brake on then the bike goes down???? <_<
im in the same predicument mate. Just starting getting comfortable with backhop and starting something new and feels like your back at square 1. All ive been doing is trying trying trying. Good thread though helps me as well :D
ben
get a little bit further over the back wheel so when you land with the brake on it brings you back to the balance point, your brain might tell you your going to fall off which is why i said in my first post keep your feet on the pedals (Y).
Thanks Mate Ill try that in a minute :P
All i can say is, get the bike onto the back wheel and pedal brake pedal brake pedal brake, expect to fall off, Go out and say im not going in til its learned, the first day i tried them i did it, took me a few hours mind :)
mike W
mike W
Cheers Mate ill try that tomorrow so like wheely brake wheely brake and keep my balance yea B)
you been on trashzen yet? linky (click me) some good pointers there, the little wheelie-lock up brake-wheelie-lock up brake methods probably the best way to learn it (Y)
Yea i saw that it pretty good but i was seeing if theres a easier way really haha.... yea ill try it then ill try jumping as well Thanks
Try doiing a little endo and then flicking the back end up quickly and remember to press your back brake then if your balance is good do a sharp little pedal and pull up by releasing the brake and when your in the air press your brake to stop you falling on your arse try and come back on the back wheel by leaning back of the rear axel then do the same as you did on the first one and once you get the hang of it it should come natural.
hope this helps i can really explane well
What do you do first pedal the hop ??? :S
Edited by shogun_gimp
I'm still on getting used to hopping on the back wheel, have a tendency of hopping backwards, which is really annoying, but getting better at it everyday. Would love to pedalkick forwards.
just before you hop like normal release the brake and kick at the pedals but don't forget to put the brake back on or you'll be on your ass
You should go on Trash zen, theyv got a good technique to get you started, or just watch a few videos and see how its done.
Its basically down to practise, practise and more practise, once you do it once you will always be able to do it.
