Rimjam
monkeymoped
>_< if i get rimjam pads and a new rim will i need to grind the rim or are the rimjam pads good without a grind?????????????????????????????
i have bin riding with rim jam reds for a short time now on a rear bmf rim with no grind
and seems to work perfect for me not sure on how well they will work with other rims best bet to do is ask wally himself
cheers biddle
should be fine without a grind but i would reccomend a very light grind, thast what i run an seriously you will not find a better pad, the noise is soo loud and the bite and hold is top notch. Just give it a very light grind and you wont need to re-grind for ageees. I have ridden in loads of dust, and chalky nasty stuff and just washed my rim when i got back but...the brake pads worked just as good no matter what. So i would advise a light grind and just clean you rim every so often unless you ride street then you wont have to do anything else. -Hugh
Jonny ran his on a msooth rim for a little while and his brake was great, i ran mine on a grind and they were good despite me having it set up gay. Stuck them on boumsongs bike and they were fantastic, nice noise, great bite and hold.
Fantastic pads.
but do the rimjams still have the retarded backing design?
They have a CNC'ed metal which is the white bit on thier design
never heard my cousts then ;)
Meh my cousts were silent, and in my opinion thats the main disadvantage for me about the rimjam is the ammount of sound they make! i personally prefer a silent running bike.
sorry to be ignorant, but do the rimjams still have the retarded backing design?
they are in CNC backings similar to the heatsink backings, they are available for refills too.
I believe rimjams went to Power Pad backings a fair wee while ago...
CNC...
im guessing yours were in the plastic backings, mine were also silent in them, but when tom got his in some metal backings they were loud and held insanely well.
for sure, but a brake like vincents or stan shaws would be the best, silent until you really need to use it where it make a slight honk
I personally like it loud, as it give me more confidance that my brake is working.
fair play, but doesn't it piss you off a treat when you are riding in a school or somewhere and everyone comes in to moan that you are riding on stuff, yet they would never have noticed if your brake didn't propel 9876 decibels
Wouldnt it be a neat idea to get, or borrow a Sound Pressure Level unit and measure the loudness of different brake pads to see which comes out top trumps. though as i stated before, Rimjam pads would probably win such a test hands down.
